2001 GMC Yukon lost Cruise control and Fog lights at re same time??
KR66
I'll make this as as short as possible. I went on a long vacation after buying a Ram 2500 Cummins to tow a Fifth Wheel around the country for a year. I put my 01 Yukon in storage in Kentucky for a year. I treated the gas at 1/8 a tank, changed the oil before putting it in storage. Everything worked when I was parked. Now that I pulled it out of storage. It fired right up after reconnecting the battery no issues. I noticed the cruise control and Fog lights didn't work? I checked the fuses and the relay for the fog lights the relay works, I don't get the light on the fog light button but I here the relay click. The cruise control doesn't work at all. Is there anything in common anyone knows if that can take both out at the same time? I know a rat or mouse could have chewed on something somewhere I checked under the hood and under the vehicle for signs of a rodent damage but don't see anything no nest or droppings. Everything else works fine. I may have a issue with the key fob it stoped working I'm waiting on replacement from the dealership if that doesn't work then 3 things went out that are somehow linked together somehow? Any ideas where to look for a broken wire or loose ground that could take out 2-3 of these things?? Thanks I hated putting her in storage but I was the only driver my wife can't drive anymore.
K
KR66
Just found my Door Ajar stopped working also on all doors something has to be related to all of them? Nobody has any ideas??
5x10
Not sure if this helps, but I recently changed my tail lights with new leds ones
The new connectors were plugged in the wrong way(had to turn them over)
But, while they were plugged in wrong, my cruise control wasn’t working
Maybe tied to the brake lights???
Not sure what all impacts the cruise
K
KR66
Thanks I did put LEDs in the entire vehicle but it was over 10 years ago, had to install resistors. I'll try putting in old school lights as a test but I think it's something else because whatever it is took out the door/hatch open warnings as well? This has me really baffled.
WITCH1975
