EddieC
- Joined
- Aug 9, 2014
- Posts
- 966
- Reaction score
- 801
Should the engine accessory drive belt be routinely changed?
unless you are talking about a k2xx then the gmt900's only have a serpentine belt & ac belt and yes they should be changed, probably not as often as the dealer will try to talk you into though, it's easy money for them.Should the engine accessory drive belt be routinely changed?
Book maintenance interval is 100K. I change mine every 50K or whenever I have to remove it for something.unless you are talking about a k2xx then the gmt900's only have a serpentine belt & ac belt and yes they should be changed, probably not as often as the dealer will try to talk you into though, it's easy money for them.
but you can safely go a long ways, my preference is to change them about every 50k
if yours looks cracked or has edge wear or thread coming out of the seams then it's probably time for a new one.
I replace the tensioners and idler pulleys every time I change a belt. The bearings barely outlast a belt in my experience.Here they are at 120,000 miles and 16 years. The camera macro pictures are much more telling than the naked eye sees.
The AC belt was much worse and used less. Not sure that makes sense.
It's a very easy job. More effort was needed to get the bottom splash cover on because of the front bolts into a pipe section than to actually change the belts.
Followup question though; how much effort should the tensioners be giving back in the process?
I'd seen some videos and it appeared that the guys were busting a gut to keep tension off the belts while changing.
I just used a standard 8" ratchet and it was a breeze, just a second thought in the whole thing.
aside from using some kind of gauge, then no tellingSo beyond the obvious bearings, how does one know about the spring tension on the belt?
Let's put it a different way.
Not being interested in an actual number, how do we know if the belt is tight enough indicating that the tensioner is not worn to the point of not being effective enough?
I’m sure there is a spec but I have no idea what it is. Mine move relatively easily with a ratchet also.Let's put it a different way.
bottom line without a gauge and a spec to reference then just consider it a wear item and replace it, usually if there is a problem with it then it's starts making noise.Let's put it a different way.
