2008 tahoe 5.3l in need of desperate help
Super Moderator
Elev 5,280
Any changes to the injectors? New o-rings when reinstalled?
Charles Hughes
If the cam is original and the lifters are new then that could be causing it. Lifters wear to the cam.
N
Nickct203
You could have two bad plugs -- it wouldn't be the first time. Pull, check for carbon tracking or cracked porcelain, and swap them to good cylinders.
Im gonna have to run there tomorrow after work and see if I can add some 2 cents to this.
N
Nickct203
Ok just talked to my buddy, he did the dod/afm delete on it and did the tune for the ecu so it would accept it.
Super Moderator
Elev 5,280
Make sure he did (or does) the CASE relearn, 'cause new cam and crank sensors.
Super Moderator
Elev 5,280
It's a quick process -- he should do it just to rule it out. It may not be what's causing the misfire but it's on the list.
N
Nickct203
First thing we will try when I get out of work. Thank you. If this isn't it I'm really drawing a blank
Marky Dissod
Talked to him this morning he never did the CASE relearn
Typically pcm tuning includes bypassing the CASE relearn so it need never be done again going forward.
That's likely what the tuner meant.
waiteben84
