What oil and plugs in your Hoe?
ypsetihw
Lakewood, CO
title says it all - have to do an oil change on our 01 Tahoe . . . and I'm guessing it needs plugs because my GF has no idea when they were done.
several questions:
what oil filters due you use? are there oversized filters approved? anyone have a stock part number for a k&n oil filter replacement on these trucks?
what oil do you use? I'm a fan of full syn but not sure if these stone-age engines need different weight than my jetta - maybe 0w-40? or something thicker to smooth out the lifters?
what spark plugs do you use? it seems like everyone uses these crazy 100k mile platinums, but I usually prefer copper core for better spark - even if they need replaced every 20k . . . what plugs (and part number) do you use and what is the recommended gap?
:beer:
amaz
Helsinki, Finland
I'd definetly go with AC Delco platinum spark plugs. Seen so many times how Bosch/NGK/etc. plugs just don't work with these trucks (misfire, hesitation, bad running)
I've been using full syn 0W40 until yesterday. I was amazed, because with mobil esp 5W30 that ticking noice from left bank was gone (I assume lifter made that noise).
hassoun
Germantown, MD
haha easy there bud.. i use Royal purple 5W30 and i have ticking noise from time to time. thats why im wondering. i highly doubt Mobil is better than RP but who knows
Sasquatch
Orange County N.Y.
Royal purple 5W 30
WIX/ Napa gold filter
Only 39k on the odometer but i`ll stick with AC for the plugs when i change them.
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
the A/C Delcos ARE ngk plugs :) I'll try to do mine tommorrow.
i use supertech (penzoil) 5w-30 synthetic.
The ac delco filters seem to be made by the same folks that make the supertech filters, so i just saved the buck this time.
no ticky... after it warmed up for a minute (winter) or now that it is over 50 degrees out. it probably had dino oil in it when i bought it so i expect the lifters got cleaned up over the last 4k ish miles.
It will get an early oil change in two weeks before i leave on my trip (est. 3500 miles in 2 weeks) the engine should be nice and clean internally.
Dynamo
Austin, TX
For my '03 Tahoe LT (5.3)...
oil filter: ACDelco PF46 (got a PF46E for the next oil change though)
oil: Mobil Clean 5000 dino oil (no ticking)
spark plugs: ACDelco OEM replacements (platinum or whatever they were)
Still runs great. :) FWIW it's my personal belief that all of this worry over what brand, type, etc of maintenance products is much ado about nothing and that regular consistent maintenance using whatever brand is the key to longevity. I've never had an engine that blew up because I used cheap oil and a Fram filter, but YMMV. :)
gcletsos
Mobil1 5w-30 High mileage
Purolator Filter
I previously used conventional oil. Engine temp dropped about 10 degrees and oil pressure increased about 5 psi
ypsetihw
ypsetihw
Lakewood, CO
there was a sale at my local o'reilly. they just started carrying their full syn o'reilly blend, it is made by shell. I got 5qts and a mobil 1 filter for $17.99!!! with the extra qt of oil and some shop towels, the total was only $27 for a full syn oil change and killa filta . . . beat that midas!
91RS
GA
I use Mobil 1 5W-30 and the Mobil 1 filter. Best part is you can usually find Mobil 1 on sale and basically get the Mobil oil filter for free when you buy 5 qts. of oil. A good quality oil change is sure cheaper than a new engine so I'll keep "wasting" my money and buying the good stuff.
The same company that makes the AC/Delco filters may make the Supertech filters but that doesn't mean they're the same. The same company that makes the Delco filters make the Mobil1/K&N filters but I assure you they sure aren't the same filter. AC/Delco actually just released a new design of some of the filters that are supposed to be better.
mkaresh
Hoe? Unless she demands cash every time you visit, that doesn't seem very respectful. :)
It's hard to find solid information on oil. Some of the best discussion I've found on the Internet is at bobistheoilguy.com.
Eagle
EL PASO, TX
RP gets its 'better power: dyno proven' status from being on the very low edge of the viscocity tolerance (for any given range)
Ie a 5w30 is probably closer to a 5w25... thus it does read higher on a dyno.
A/C Delco is a rebrand 91rs, and their 'redesign' is for cheaper per item cost, not better build quality or more ruggedness.
Drewphil
