reprograming onboard computer with new shocks
Rodie40
::UPDATE:: I aired up the system and it sounds like I blew the driver shock. What do you guys recommend for shocks? I would like to keep the stock setup as I just put in a compressor. Thanks.
Geotrash
Dave
Richmond, VA
Reviving old thread again...I just replaced the compressor in my 2007 Yukon (Z55) and it aired up fine by itself, and then more when I attached my trailer, then as I was loading stuff on my trailer (with the truck off) I heard a loud POP? I am wondering if It blew a shock bladder? It seems to be leaking at the drivers side shock. Has anyone experienced this? If I need to drive I guess I will take out the fuse so I do not burn out the compressor.
This is one way that they fail - already weakened from age and use, then placed under load.
+1 to Tom's recommendations. You can buy OEM on RockAuto for a good price, which is what I did.
ivin74
05 NBS Nali
Htown, Texas
Check the hoses, might just be a connection that came undone.
Rodie40
Thanks, I aired them up and it did seem to be leaking at the shock, but I will check again. What is the process for new shocks? Can I just put them in and roll, or do I have to do fancy stuff like raise the truck and lower the rear and cycle the compressor with a scanner? Are the shocks the same for all Z55 200-2014? Looking on Marketplace.
Just install them and you should be gtg. There’s a calibration process called ALC trim set that can be done with a Tech2 or similar but it’s really not necessary.
18Nali
Another revival because I need help and this seems to be best thread/info I’ve seen. Background: 2018 Denali XL. Purchased used that had arnott front unit put in by local dealer. I always thought the nose sat low as it scraped on driveways and parking blocks. Also looked like it had some negative camber.
Fast forward: towed the camper and the whole system aired up and the fronts looked they should have. Unhooked after the 300 mile tow and back to negative camber. Also I noticed significant abnormal tire wear on the insides of the tread.
My question is will the alc reinsert procedure correct this issue? Should I clean the sensors on top of the units. Or do I attempt to take to the dealer that did the work? Thank you!
kbuskill
NE. FL.
I'm not super familiar with the '15 - '20 trucks, but to my knowledge they don't have any front air assist struts. They should be just like the GMT900 series and have auto leveling in the rear only.
I would take it back to the dealer if there is a problem.
petethepug
Michael
SoCal
Eventually you’ll be moved to the 15-20 forum
This isn't the correct forum for your year, so we recommend that you start a new thread for your issue.
AdrienR
