First year ownership and 5K miles 2011 Yukon Denali
MWD_CTSV
I'm looking at my recent NC safety emissions report and it is 5K miles (219K) since I had it inspected last year at 214K miles. I actually had to get a 10-day tag and pay a fine to take it for inspection because it was 2.5 months from when I bought it and past due for inspection.
I'm not really a truck person, although I have owned a 1974 Bronco for 30 years, but all others are uni-body. Well ok, not the Factory Five, but it isn't a truck.
The GMT900 platform has really grown on me. At nearly 220K miles, it really surprises me how young it really feels, and how the platform feels like a 500K mile design (with maintenance). It still is a truck, but it drives well, cruises well, has good power, holds lots of passengers with plenty of space, tows well, and is well a huge amount of carrying capacity. I moved kids into a college dorm and a college apartment last summer with one trip each, and there was room left over. We took an exchange student, my wife, 3 of my kids and 5 bikes on a long weekend through the VA/NC/TN mountains and everyone was comfortable.
Maintenance replacements (not necessarily needed but preventative lets say):
Engine/Trans:
-GM radiator
-GM transmission cooler hoses
-GM oil cooler hoses
-AC Delco water pump
-GM Coolant hoses
-GM heater hoses & plastic Ts
-GM valve springs
-BTR trunnion bearing upgrade
-Plugs & wires
-Passenger coils
-Intake/Exhaust gaskets
-AFM/DOD delete
-OSC PVC oil separator
-Passenger motor mount H3 upgrade
-Denso O2 sensors
-6L80 rebuild
-Injector cleaning
Suspension:
-GM rear Z55 air shocks
-Dorman rear air pump
-Front Sway bar links
Upgrades:
-Black Grille
-LED headlights plus Diode Dynamics LED switchback turn signals
-Rear Brake/Backup LED bulbs
-3DS floor mats
-2022 PPV 6 piston front brakes (awesome)
Realistically only the valvesprings and rear shocks/air pump were the only true failures needing some attention, but I get a little carried away.
M
MWD_CTSV
So a little backstory....
My friend is looking for a used truck to replace his tired 2003 Ford F150 with something safer, but not too new that he is afraid for his 15 year old to drive it to school. Late 2022, he brings me a 2013 Silverado from the Northeast. Aside from the rust, I am pretty impressed overall with the platform. At $20K, I tell him he can do better, so I am scouring the internet for owner listed Silverados. I see a 2011 Yukon Denali pop up on Facebook with 214K miles for $6K, listed as a mechanics special that has a failed lifter that has an estimated replacement cost of about $2.5K. So I do the research into the AFM/DOD lifter colllapse problem, and put it on the back burner. Well 2 weeks later the listing is still up, so curiosity gets the best of me and I arrange to go take a look. My friend has already found a local NC owned 2015 F150 for $15k, so he is happy, but this Denali is still on my mind. The vehicle has good bones so to speak, and nothing seems to be wrong other than the missing cylinder, so I tell them they should fix it since it would be better to invest a small amount in an otherwise good vehicle. But they have already bought another Yukon, so I think for a minute and offer them $5K, which they are happy with.
I bring it home and order the crazed performance lifter tool and DOD delete ring full prepared to try and unlock a stuck lifter without removing the heads. I am fully ok with removing the heads and replacing the lifters, but the idea of unsticking a lifter to have a potentially longer operational life without DOD for pennies, really intrigues me for some reason. There was active misfires on several cylinders as well as misfire codes plus an open circuit code for injector #2. So I start digging in with the ignition parts off and the intake removed, fully ready to unstick a lifter.
After I pull the valve covers, I find this:
I'm sure you can all spot the problem. A $4 valve spring. The previous owner was quoted $2400 to fix the problem. The open circuit on the injector was not a wiring problem, but just a diagnostic removal of the connector during previous troubleshooting. I guess it is also partly a miracle the spring broke on the lower section and didn't allow valve to piston contact. Crazily, I actually drove it about 15 miles home at low speed.
So long story short, the original lifters are still there. New valvesprings and a good injector cleaning and the engine runs like a champ.
j91z28d1
did you leave the afm active or deactivate?
I can't help be be curious how same go 200k working and some sick at 100k and others eat non afm lifters. I get that oil plays a role, but the previous owners don't sound like car guys changing oil every 3k.
it's such a mystery to me. I just hope mine is more on the 200k side haha
Trey Hardy
Hell yea! I unstuck my lifters twice with marvel mystery oil my engine in the Tahoe is at 400,000 now
M
MWD_CTSV
I deactivated AFM in the computer and I inserted a blocking ring into the manifold to block oil pressure to the solenoids.
The window sticker showed this was sold through a local dealer. It was also sold as CPO around 100K miles, so it was clearly well maintained and the CPO purchase included an add-on for x number of oil changes. There were also receipts for synthetic oil changes in the glove box.
The owner I purchased it from had only had it less than a year, but they did say the previous owner had given them an oil pan gasket and suggested they replace it, which they did. I'm pretty sure this one had regular oil changes, which makes a huge difference. The cam lobes that I could see with the intake off looked very clean.
j91z28d1
nice, I did the same mod to mine at 135kish. at 155 now. the car fax showed oil. changes ever 10k or so early in its life. unless they changed it in between and it was registered but it looks super clean inside. I just didn't want to take a chance. I also don't want to take to apart for a full delete haha.
looks like you got a deal. very cool
petethepug
Michael
SoCal
That really sucks the previous owner got hosed by their shop. That shop probably ordered a new valve spring and spray paint for new looking heads that were never intended to be pulled.
The GMT900 are really predictable and owners tend to not maintain them. That’s a testament to their longevity because they tolerate the lack of maintenance and get sold on when they break. Kinda like you ran into :)
M
MWD_CTSV
That is very true. I think the increased reliability can breed a lack of concern for maintenance. I also feel like some of these computerized maintenance minders imply that 8,000 miles is ok for oil change and maybe some will just think the yellow/orange light is more like a suggestion. It also makes it hard to determine true value for a used one.
I don't really blame the shop for quoting lifter replacement. It was a believable possibility to me, and I would probably give a quote for the most costly probably as well. Of course, if a shop charged for new lifters and simply replaced a valve spring and spray painted the heads, that would be very sad.
adventurenali92
Big Bear Lake, ca
Dang!!! you scored a really great deal on a nice truck and really bulletproofed it! I’d love to be able to do the same with a GMT900 soon! Nice work and thanks for sharing the journey with it! Really clean truck!
Rwmullis79
I’m about to roll over 240k in my 2011 Tahoe and my AFM is still active. One of the lucky ones I guess.
j91z28d1
this is so interested to me.
I'd love to know what the difference is. I mean can it just be luck? any details on oil/filter you use and how often?
vcode
I guess the question that needs to be asked is what is the real % of engines with DOD issues? There are millions of engines out there and I would guess 90% of them have no issues. Now 10% is still a big number, but is that what the real % is? Even if every person on this forum had a DOD issue, it would be just a small % of the number of engines out there.
j91z28d1
that is true, most normal. people don't start researching till the shop gives them a $6k estimate, and the amount of vehicles that end up in the junk yard long before 130-150k is very high and even less that still have the first owner. so they could be repaired while passed around auctions and stuff
but my take and I base this off nothing but my gut feeling is say of the 100% that make it to say 250k miles, which may be a lot or may be normal depending on your experiences with cars and life style in general. I would be surprised if more than 1%. make it there without lifter issues of some kind if you follow manufacturer recommendes service.
but I have been called a salty old man for being negative lol
vcode
So 99% of trucks that get to 250K miles have lifter issues? No way......
j91z28d1
sounds about right to me... one thing I've learned since getting mine and being on this board. the stuff that commonly breaks at a certain time or mileage, breaks like clock work. pop it's done. my first thought was nah, I bet it's just the unlucky but nope. mine has hit every milestone just about on time.
the amount of people that have new engines thrown in the trucks by the local shops is crazy. if you ever get bored, check youtube videos about afm, and scroll thru literally 1000s and 1000s of comments. i just don't see any evidence of afm going 250k plus with any consistency. if I thought mine had a any chance I would never have shut it down.
vcode
You don't see evidence because only those with issues report them. 1000's and 1000's of comments is a blip on the radar when there are millions and millions of engines out there. Besides, 250K on an engine is pretty good life no matter what! :)
petethepug
Michael
SoCal
I just noticed the BTR trunnion bearing upgrade. That’s pretty slick. My L9H is worthy of that at 190k now.
You’re literally following in the footsteps of my past 08 Denali maint records and have successfully met, headed off or overcome every known hurdle.
When your in the path of LS predictability like that it’s kinda cool to think ahead 5-8 years from now about adding a s/c or dropping it off at the limo shop to add the 3rd set of doors because it’s a cheaper and better alternative for a replacement vehicle they don’t even make yet.
Geotrash
Dave
Richmond, VA
I installed these in my 2012 when I did the cam swap based on old information about factory rockers spitting out their bearings. But apparently that was only happening on very early LS engines (~'99-'00 IIRC) and GM has long since corrected the flaw. These days they're more of a gimmick, IMHO.
Geotrash
Dave
Richmond, VA
This is all true. Perhaps the best way to frame it is as a risk factor for reliability and longevity, nothing more. How much of a risk, probably only GM can say. And it's one that can be mitigated completely for a reasonable cost (for a DIY'er). But we also have at least 6 model years of the previous generation of non-dod engines to compare our perceptions against. The sheer number of those still on the road with 400K+ miles, is testament to their durability.
For me it was never about the cost of fixing it if it breaks, but rather the price of potentially having to deal with a breakdown miles away from home. We use our 2012 (cam swapped and dod-deleted) almost exclusively for long trips pulling a camper, so for me it was worth the investment of time and money to mitigate the risk, plus I got a power boost from the cam as well.
tkdgirl
Michigan
My 2011 Denali XL, other than an engine rebuild due to sticky lifters (yes, it's deleted and tuned!), has been wonderful. It's basically brand new. Picked it up with 113k in 2021 and now at 160k. The body is flawless (Cali car) and just saw its 1st winter with a complete Krown coating and removed the boards for the winter to prevent trapped snow. We've hardly had any snow here this year so added bonus. The dash, OTOH, cracked in multiple places and needs to be replaced.
Replacing a cheap knock off hood chrome piece this weekend with OEM part. Need to replace both mirrors soon. Anyone have the right part number for full featured DL3 mirrors? Can't seem to find one with all the bells and whistles. Also wondering if the Denali had chrome caps?
1948Buickroadie
