how to protect your rig from salt damage??
Jocko PDX
Portland OR
I live in Oregon, and they just started using salt on the roads last year.. For those who live in states where they salt the roads in the winter, what steps do you take to prevent salt damage? Undercarriage wash at the car was? Anything else?
that331racer
Undercarriage rubber coating is the best way. It can be expensive, but it is worth it. If you are more on a budget, undercarriage washing is the best.
Baja_Bob
Michigan
A good paint sealer or ceramic coating, if you're old school, a coat of wax.
Or a dependable winter beater, that's what I do.
GMT800 2005 Tahoe Z71
Navy Supporting Member
I live in Oregon too and have not heard of the "salt on roads" claim. I have known of a solution they use on some of the passes but are you saying Oregon is using rock salt on roads and where? There is a tool that you can buy at Amazon that you attach your water hose to and it rolls under the vehicle and has multiple spray jets that will spray up under the vehicle as you roll it under the vehicle.
ODOT's winter highway maintenance practices reduce costs and limit impacts on natural resources while maintaining high standards for public safety -- our No. 1 priority. ODOT's standard practices during snow removal include:
  • Reducing plowing speeds in sensitive areas
  • Minimizing snow blowing into sensitive areas
Sanding material is sometimes applied on roads and bridges to provide better traction for safer driving. ODOT's practices minimize effects on natural resources by:
  • Reducing application rates and frequency of sanding when weather and traffic conditions allow.
  • Minimizing sanding in areas with air quality problems or near waterways and other sensitive areas.
  • Placing barriers to capture sanding material along sensitive waterways.
The use of deicer is an effective way to improve road surface safety during winter conditions. ODOT uses magnesium chloride (MgCl2) with corrosion inhibitor and solid salt (NaCl), both as an anti-icer before a storm to help prevent ice and snow from bonding to the road, and as a deicer after a storm to help break the bond between ice and road. Use of these chemicals has been proven to improve road conditions, reduce crashes and mobility restrictions and reduce the use of sand - which limits impacts on air quality, water quality and aquatic habitat. We continually strive to optimize application timing & rates of these products. ODOT uses:
  • The lowest application rate necessary to achieve desired road conditions.
  • The strict specifications of the strict specifications of Clear Roads, a consortium of snow states and provinces dedicated to safety and performance.
We believe protecting the environment while providing a safe transportation system is a smart move. Plowing, sanding and deicing do not, however, make the road completely safe. Travelers have a shared responsibility to travel safely. Drive at speeds appropriate for road and weather conditions; consider delaying travel if necessary.
Know before you go: Visit www.TripCheck.com, Oregon’s travel information website, for up-to-the-minute road conditions and more information on Oregon’s chain law and chain requirements. You can also get the latest in road conditions by calling 511.
Jocko PDX
Jocko PDX
Portland OR
we don't get a lot of snow here in the valley, so I am only dealing with it prob 1-2 times per year, prob don't need to go to the extent of getting a rubber coating.
WalleyeMikeIII
Sunny and Snowy Minnesota
You don't....you can minimize/reduce the impact...but you will get rust when driving in areas where roads are treated w/ Salt or MgCl2.
Best thing you can do:
Wash Frequently
Do underbody rince whenver possible.
In the Spring be sure to rinse all the undrbody.
Most people here use an oil based liquid undercarriage treatment vs the rubberized/hard one.
The hard one tends to chip, and once the surface is broken...salt water seeps in...and you are back where you started...or worse, cuase now theat undercoating is holding the stuff against the metal.
Here in Oregon, I believe the liquid and salt is only used in the passes and higher elevations where there is enough traffic. I hardly ever go thru the passes, so I don't worry about it. I do warn the people that I work on cars/trucks for, if there is rust caused by the salt or whatever it is, I do not guarantee that I might have to deal with it and charge accordingly. If you live at the coast around here, there is salt in the air and that leaves surface rust on all kinds of surfaces.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
:deal:
15burban
Wisconsin
They salt the crap out of the roads here in Wisconsin. Every spring and fall I'll wash the undersides really well and then touch up any rust I find with rust preventer. Then a week later go back under the vehicle and spray fluid film every where I can including removing tail lights and spraying behind them. Not much behind them on the suburban but can cover quite a bit of the inside bed side on my pickup.
The fluid film isn't the greatest (waxy/greasy) if you have to do any work, suspension or what have you under the vehicle, but it sure beats the hell out of having to fight rusted nuts and bolts.
89Suburban
SE PA
I am a huge underbody wash guy. Last time I tried sealcoating/painting a chassis it chipped and and rusted from the inside out and you could not see it until it was too late. Some of the northern rednecks use spray oil stuff I forget the name of it.
Here was my last victim of frame rust. I miss her REAL BAD. You can see where ith cancer was growing under the paint.
strutaeng
Dallas, Texas
I asked why a coating isn't the best option on the garage journal forum and guys up north mentioned the rock chips. I guess that's a valid point...they seem to prefer a wax-type of coating, but the issue I see is you have to constantly be reapplying it. I've watched videos and guys say it takes up to 2 hours for a thorough job and really messy. Yikes.
We don't have rust here (mainly just surface oxidation), so I can't speak from experience, at least not automotive.
I do deal with corrosion on buildings at my job. Either steel framing, or rebar corrosion. In that industry, coatings are what we specify: epoxies, 2k, alkyd, and other specialized coatings. Obviously, we can't have a contractor apply a wax annually or whatever. Service life is typically 20 years, but may more than 50 years. Some buildings I've looked at are like from the 1920s.
I was watching a Nova show on the Eiffel Tower recently. They mentioned it had 19 coats of paint since it was built, average like 6 years per coat, or something like that! Imagine applying fluid film on that thing twice a year, LoL.
Sorry if this doesn't really help much...but here's the video if anyone wants to watch it. I found it fascinating, especially since it was built...like 135 years ago!
Jocko PDX
Jocko PDX
Portland OR
The city of Portland uses salt now as well. That is where I live. The following is from KGW news article:
There was indeed a time not that long ago when PBOT and ODOT both avoided putting down road salt, mainly for environmental reasons. Salt can damage roads and bridges or build up in streams and rivers, and it's not great for cars either.
Oregon's relatively mild winters made it easier to get by without salt, but ODOT began testing salt in 2012 in response to more frequent snow and ice events.
PBOT eventually followed suit, and a big catalyst for the change was the exceptionally strong winter season in December 2016 and January 2017, when icy gridlock kept the roads clogged for days and public frustration with the saltless city reached a fever pitch.
Not long after, then-Commissioner Dan Saltzman announced that he was revamping PBOT's winter storm strategy to add more plow routes and expand the use of road salt for future weather events.
Today, salt is a regular tool in Oregon's winter weather toolbox. When a major ice storm was closing in on Portland in 2022, PBOT and ODOT both told KGW that they would have salt ready to deploy along specific routes, along with magnesium chloride deicer and sand.
During the February 2023 snowstorm, PBOT said it had responded to the current winter storm by applying 45 tons of salt, plus 8,000 gallons of deicer, along the city's priority snow routes.
The city has also published an FAQ for residents and business owners about how the help minimize the environmental impact of wintertime salt.
Politicians do not mind damaging your vehicles with the salt. Suttle references about climate problems stroke the very liberal Portland politicians with nary a care for Oregon vehicles. Effffffffing idiots.
Jocko PDX
Jocko PDX
Portland OR
yes I think it is silly to use salt on roads in PDX when we get only a few days of snow every year. The big problem is that Portland drivers suck..
StephenPT
St. Helens, OR
I think it was about 2016 - I made it to the office and there was no snow, as the day went snow started to accumulate. By the time I got out of my meetings, the Fremont was complete grid-lock. I had to go home via the St. Johns bridge and my normally 35min commute home took 3.5hrs. Some other co-workers didn't get out as soon and ended up sleeping at the office.
WalleyeMikeIII
This is why I live in MN!
Yes, they salt the heck out of the roads, but we can get 14-16 inches and 24 hrs later everything is cleared. And, people actually learn how to drive in snow. Now, about the corrosion…fortunately it slows way down when the temps are -10 or -20!!
Yukon 4WD and some Blizzaks and you can get through most things…Wash often in the winter. Figure 8-10 years max on a vehicle and trade it…
I am well aware of Portland driver habits. I live in Eugene. I absolutely hate driving around here and stay the hell away from Portland altogether. Freakin' idiots up there. Not you though, I am sure.
Came from KC, Mo. area and learned a long time ago how to drive in ice and snow.
NothEastTahoe
NH Oil, and if you can't find that, get fluid film. Re-apply every 1-2 years. Your truck will be brand new underneath, besides your exhaust, forever. Yes it is messy to work on, but lets be real, you ain't working on your yukon, and neither is anyone else with a new model on this forum. Application is messy as well. There are guys who will do it in their driveway, and companies as well. I would recommend that. I wouldn't personally do it myself due to the mess and disposal of all the product after. Let the tech deal with it.
In Mass, where things are expensive, it cost me $250 dollars for my Yukon and same for my truck. They did raise their prices two days after I got it done again to $280.
Rubber coatings are bad and will destroy your frame, as another poster mentioned. Do not ever do that. Anyone thinking it was smart, go take it off your truck right now, you were lied to.
https://nhoilundercoating.com/ this is the NH oil the place I go to uses. Woolwax is another very popular brand.
you can mail me $10 for these wonderful life lessons if you feel like it.
justinakay79
