ss4chad
Fort Worth, TX
What is a Italian tune-up?
Per the BING Co-Pilot:
An Italian tune-up is an unconventional method of car maintenance that involves driving at high RPMs to clean out carbon deposits from the engine.
Hmm, I thought it had something to do with pouring Red Wine in the gas tank? Looks like I learned something today!
Chad
K2 Kaiju
The Depths
Chad
Yes - you do several full throttle 0-60 (+) runs to get the engine heated up and knock loose all the crap. It can be bad if you have a weak link somewhere, but every time I have done it the engine runs a lot smoother...
Sparksalot
Bastrop County, Texas
Took a selfie.
Jeff_
Scottsdale, AZ & N. Idaho
Well I ripped apart my interior and installed my Kicker sub. Followed every single instruction exactly.
Turned on some music and the sub itself makes no sound..
I'm unsure if it's because I need to go to the dealer and have them eliminate the ANC (active noise cancelation) through a reprogram. I know the installation manual says to do that. But I figured it would still work somewhat before having that done and then just be optimized after that was disabled.
Fingers crossed that all I need is the quick trip to the dealer and to pay $50 for them to reprogram in order to get this sub to function..
(pic of things torn apart for your enjoyment)
Chad
lol, I do those every day!
the ANC shouldn't stop the sub from working, all it would do is cause some undesirable feedback, kind of like having a mic to close to a speaker and instead of a high pitch squeal you would get a rumble. double check your work.
Cryptothedog
Also blacked out my rear emblem. I need to redo it though. I messed up on the cutting of the vinyl.
Thrust
ICT
Changed the transmission filter and fluid in our 2015 XL with the 6l80e. I think this is the first time the filter has been replaced at 93k miles. Fluid has been changed a couple times before this. Used my venturi brake bleed setup with some extra hose to suck out the fluid. Once I had the pan down the filter looked pretty clean. Magnet was coated with a thin film of grey. I couldn't get the pan out so I just used my brake bleed pump to pull the rest of the fluid out of the pan. Worked great. Cleaned the pan and magnet, new filter in, and @ 8qts of fluid added.
sent a upgrade HMI (one with oem nav) out to wams for full unlocking & map update
I pretty much never use built in nav but it's a reduncy for when we hit the mountains as cell service is pretty much non existent if you are not on a major highway. Even then it is spotty.
_tb_
Denali grille swap:
Added a K&N air/oil separator, which is a nice piece:
I also added a Superior Solutions 6L80 Sure Cool transmission thermostat bypass kit, which has to be about the best $30-ish that can be spent on one of these trucks for those who aren't interested in pill flipping.
HMI is done that was quick enough I guess, they initially said turn around was 2 weeks but they only had it about 5 days
Escalade2007
