Axle
Mudsport96
40.923,-89.488. Illinois
Look up Stapleton42 on YouTube. He has a Yukon with the 10 bolt and an aftermarket posi that was making like 450 at the wheels.... before he realized it was an AWD case and was burning up the clutches. He swapped in a true 4x4 case and was probably closer to 550. He also has like a 10 second Escalade, so the videos of that should tell you everything you need to have.
67RS427
I plan on using it as a daily with a little bit of heavy towing here and there. I mostly wanted to see if a 9.25 would help with 4wd launches and not shredding the front end. But looking into the capabilities of the 8.25, I realize that I don't need the 9.25.
Sorry I'm late to the party... Moving up to a 9.25 will not do you any good for improving launches. You're still stuck with an open diff and no limited slip or posi units available for either the 8.25 nor the 9.25. I am still running the stock front diff on my 1k HP Denali. The transfer case in mine is a BW4485 which uses planetary gears and not the viscous coupler that is prone to breaking. When comparing a 4x4 case to a planetary BW4485, they are the same, the AWD just can't be switched off. No other difference in traction due to the diff still being open.
As for not shredding the front tires, good luck if you're making over 600hp lol... I still rip off the fronts and I'm running 305 Drag Radials but making a ton of torque off idle. You need a stiff double adjustable shock front and rear. The rear needs stiff compression and the front needs stiff rebound to avoid transferring too much weight and unloading that front left tire. Helper bags in the rear help a lot and you can also chain or strap down the front arms to limit the travel.
that331racer
that331racer
Thanks for the suspension info, that was the thing that had me confused for setting it up. How would it do towing a 7500 lb trailer though?
67RS427
Are you referring to the stock 10 bolt? I'm still running stock axles and 10 bolt housing... Install some good bearings, a TrueTrac and send it. Upgraded driveshaft is also a must IMO if you're high HP. I upgraded to a 1350 yoke as well. You've got 40% of the power going to the front if you're AWD. You aren't gonna hurt anything towing 7,500lbs.
that331racer
that331racer
I was referring to the 14 bolt when I swap it in. It already is towing the 7500lb trailer in question and has been for the past 2 years.
67RS427
The stock differential is the weak link for sure. You're not talking about a lot of weight though, I wouldn't worry about it at all. The towing capacity on these trucks is around 8,000 lbs stock. Add a little more horsepower and some better brake pads and rotors and you can tow 10k pounds all day. I don't think your application really needs a 14 bolt conversion, just my 2 cents.
Geotrash
Dave
Richmond, VA
I've been towing a 7500 lb camper for the last 3+ years and 25K+ towing miles now with no problems on the stock 8.25 in our AWD, cammed 2012 XL Denali. That said, I believe @intheburbs has experienced a couple of 8.25 diff failures on one of his 4WD rigs towing. So in this case, I agree with the recommendation to get a TrueTrac and some good bearings in there if you're going to bump the power up.
intheburbs
SE MI
I broke my 2001 rear axle multiple times towing 7500-8000 lbs on cross-country trips. That was the primary reason I bought the 2008 2500 - it has the 14-bolt 10.5" freefloater I call the Godzilla axle.
Marky Dissod
I broke my 2001 rear axle multiple times towing 7500-8000lb on cross-country trips.
That was the primary reason I bought the 2008 2500 with the 14-bolt 10.5" freefloater
What was the gear ratio in the 10-bolt 8.6" axle when it broke?
strutaeng
Dallas, Texas
The mighty 14 bolt FTW...:)
TU1881
