Trailer cameras
Vladimir2306
Hi all. In our Trailer Section we have this section. Trailer cameras. Judging by the picture, these are cameras that are installed on the sides of the trailer for monitoring or maneuvering. But I didn't find any information in the accessories. Does anyone know how to use this section?
Milan
Hi mate! As far as I know, a lot of folks use this car to pull a trailer, so your car probably has this trailer option. I can't tell exactly what your picture is showing, though. But I reckon places that sell trailers and RVs would know a thing or two about these camera systems and how they fit onto different trailers. They could probably help you figure it out.
Vladimir2306
Vladimir2306
Unfortunately, trailer sellers don’t know anything about this, this is the Car section. Here it is listed in the Yukon Guide. At the same time, the section about cameras is generally empty.
StephenPT
St. Helens, OR
If you have the Enhanced Trailering Tech pkg (ZM1) - then just above your 7-Way connector you'll have two inputs for cameras. Like this -
The camera is available through Chevy/GMC accessories and looks like this - https://www.shopchevyparts.com/elec...mera-models-with-zm1/86584184-p-92317975.html
If you don't have the ZM1 package, then you won't have those inputs and the feature can not be utilized on your Yukon.
DenaliCountry
The 2 camera options are 1 for the rear of the trailer to see when backing up and 2 to see inside the trailer while driving down the highway to make sure the load is secure. Of course you can probably mount these cameras anywhere on the trailer.
DenaliCountry
What year Yukon is that off of? I have a 2022 with the Enhance Trailer Package but I don't have those inputs above the 7 pin.
Vladimir2306
Vladimir2306
What kind of cameras are these? :) how to find them and where to connect them? I don't have such connectors)
mplunk
They can be purchased from GM i believe. My Escalade with the Trailering Technology package came with them in a box in the back. Have never used them as I don't tow enclosed trailers but the idea seems pretty cool
DenaliCountry
They are a GM Accessory. I am pretty sure this is the camera but there are also other options on the accessories website. Can probably find them cheaper on Ebay, etc.
No sure why the link says site maintanence but that link goes to GM's accessory page and links to one of the camera options.
WalleyeMikeIII
Sunny and Snowy Minnesota
Do not just buy the cameras if you do not have the inputs above the 7 pin wiring harness.
This Enhanced Trailer View was an option, contained in the ZM1 Enhanced Trailering Tech package. It enables "Disappearing trailer" view, and using the trailer outside came for being in reverse when you have a trailer w/ a camera hooked up. But, if you don't have the support on the vehicle (including the inputs), you don't have thse features. It was my understanding that if the sortware on the dash is enabled, then you have the connections, but check your trailer wiring connector first...cameras are useless w/ out the software and the connection.
Here is a video about what is enabled, note this only works w/ certain box style trailers...
dizhai
