pwtr02ss
I can't even get a lowering kit installed...Build one for mine and I'll drive down and you install it.
Edit:also, has it really been two years? Damn. I prob should get that done
I can do that while you do the motor.![]()
You see how slow I work?I can do that while you do the motor.![]()
I'm right there with you. Lol. I'm slow AF too.You see how slow I work?
Looks like you dropped your flask in the next to last pic.
#gamechanger
#nomorerattlingihope#gamechanger
Exhaust hanger?#nomorerattlingihope
Yeah manExhaust hanger?
The one behind the rear wheel has slop in the upper hole. I noticed it when I was installing the rear springs.Exhaust hanger?
I hate sloppy holes. Tight is aight.The one behind the rear wheel has slop in the upper hole. I noticed it when I was installing the rear springs.
So nice new tight rubber and some lube will hopefully tighten that rear end up.
Poor girl looks cold. Bring her inside.
