Any suggestions?
Enjoy the easy drifting and donuts?
That's what I've been doing since April when a rear speed sensor failed.Disclaimer: Links on this page pointing to Amazon, eBay and other sites may include affiliate code. If you click them and make a purchase, we may earn a small commission.
Any suggestions?
That's what I've been doing since April when a rear speed sensor failed.A week or so, ago, I was doing a 'medium' acceleration / right turn on a 60mph highway. Outside my window I heard a high-pitch whine. Not loud, but I heard it..... It went away in 200 feet. I heard again for a moment, ...but I haven't heard it since then.... I wonder if the sound is a warning?Was taking the Hoe to MV, around the corner from my house I lost forward overdrive--wouldn't move in any other gears. Fluid is still pinkish/reddish, not burnt. Then it finally decided to move. Drove fine on the highway, so idk. I hope the transmission isn't calling it quits. No cel either.
Yup, I'd definitely say it is. Checked your fluid level and color? How many miles?A week or so, ago, I was doing a 'medium' acceleration / right turn on a 60mph highway. Outside my window I heard a high-pitch whine. Not loud, but I heard it..... It went away in 200 feet. I heard again for a moment, ...but I haven't heard it since then.... I wonder if the sound is a warning?
Is it the stock trans? Ever been rebuilt before? If not they usually go around 150k.Fluid / color good ( fluid-filter changed only 2 months ago when the rear main seal was replaced)
173,000 on the clock. ( I am not panicking...... my mechanic's dad is a transmission surgeon at his shop. ( the cost?..... It is, what it is )
Thanks, Grinch........Is it the stock trans? Ever been rebuilt before? If not they usually go around 150k.
Dumb question, but could it be the power steering pump? It just seems like what you heard is a symptom for so many different things that you wouldn't want to jump straight to the transmission.A week or so, ago, I was doing a 'medium' acceleration / right turn on a 60mph highway. Outside my window I heard a high-pitch whine. Not loud, but I heard it..... It went away in 200 feet. I heard again for a moment, ...but I haven't heard it since then.... I wonder if the sound is a warning?
Was thinking same thing, I noticed mine at a turn and found out it was low. I have a small leak somewhere.Dumb question, but could it be the power steering pump? It just seems like what you heard is a symptom for so many different things that you wouldn't want to jump straight to the transmission.
Thanks, Grinch........![]()
Huh...... I'll check the steering fluid..... Honestly, I don't remember the last time I checked it...Was thinking same thing, I noticed mine at a turn and found out it was low. I have a small leak somewhere.
Yup... powersteering reservoir is.... LOW ..... ( Whew ! )....... Thanks, guys...Huh...... I'll check the steering fluid..... Honestly, I don't remember the last time I checked it...
Update will follow.....
I just go to Autozone and see what is recommended for my truck. We've had both Suburbans have Power steering pump leaks. My daughter and my wife learned how to keep them topped off until we could afford to replace the pumps.Yup... powersteering reservoir is.... LOW ..... ( Whew ! )....... Thanks, guys...
I have to buy some. ( what type fluid? - regular stuff?? )
gas prices go up every summer, and drop every winter, its a demand thing.Gas prices will go down the closer we get to the election. They always do -- doesn't matter who is in power.
