Installed eonon head unit. Static from speakers
ny_summit
2007 gmc yukon xl denali with factory navi and bose.
I just installed a head unit from eonon model #GMA12S-6G. Theres a static playing from the speakers that will stop if i mute the radio or volume 0. I aslo noticed the radio is pretty loud. Even level 1 is louder than it should be. Im not too familiar with electronics and wiring but the whole thing was plug and play.
I did email customer service but wanted to see if anyone here had a similar or issue or might know what the issue is. I've done some research I've found some older forums where they say its because of the bose system.
I'm not sure what the source of the static is, but an aftermarket head unit and Bose speakers most likely created an impedance mismatch. Most aftermarket head units are tuned for 4 Ohm speakers, and Bose speakers are usually in the neighborhood of 2 Ohms. This will overdrive your head unit's power amplifier, and this is most likely why the sound appears to be louder, even at low volumes.
On my 07 Yukon XL Denali, I replaced the entire Bose system with an aftermarket system with all components compatible with each other.
ny_summit
ny_summit
Thanks for the reply. From the research I've done seems the bose system is usually the issue. They advertise that's its plug and play and works with factory bose system. Still waiting for them to reply. Other than that everything is working.
ny_summit
ny_summit
Well the company contacted me, they helped me lower the volume through the radio settings. But I still have static they recommended me to ground the radio to the frame of the vehicle
Give their recommendation a try, though I'm not sure that it will resolve your issue.
ny_summit
ny_summit
Seems like you were right. I attached a wire to the ground pin that they told me to use. Anywhere on the vehicle I touched the other end to made an additional static sound with a low pitched buzzing sound as well. So I believe the ground isn't the issue.
That is what I thought might happen, as you created a ground loop doing that.
ny_summit
ny_summit
I had Amazon send me a replacement and there's still the static/ white noise. So I'm assuming it's something with my truck. I spoke to a couple people on a fb group that have the same head unit in their denali with no issues. I'm not that experienced with electronics so I'm not sure what can be causing the static.
After doing more research it seems that's it's actually more of a hiss from the speakers rather than a static. From the reading I've done seems the amp on the new head unit is adding to the factory amp for the bose. That's why everything was much louder and having a louder hiss
That is entirely possible, if it is just a hiss that you were hearing. That is totally different than static. I am assuming that there are input gain controls on the Bose amp, but I have not dealt with one to any extent. But, if those gain controls exist on the Bose amp, then turning down the gain should reduce the hiss.
blackelky
There's a module you have to buy for the bose amp. It's on crutchfield, if they are aftermarket speakers the ohms are off from bose factory amp and aftermarket speakers.
ny_summit
ny_summit
Yea I believe it's a hiss not static. When I attempted to add the ground the additional noise was on top of the hiss. I don't know much about the factory amp.
This head unit I got came with the complete harness. My factory back up camera works. Rear entertainment and screen works. Even the on star works. Everything is factory in my denali. Can you send me the link to the module?
1948Buickroadie
