2016 Burb - New Built 6L80 and Circle D Converter going In Soon
usaf27
This Wednesday. Installing my rebuilt 6L80 and Circle D converter 1800-2000 stall with Penzoil Platinum full synthetic LV ATF.
The builder said my 4-5-6 clutch was smoked and there was slight scoring on the pump. He rebuilt the trans, gave me a new pump and installed some Sonnax upgrades that I provided.
When I bought this Burb it had 94,000 miles on it. All stock. I had done a Diablew tune, and superior Tstat bypass. Serviced everything including a pan drop at 94k miles. The magnet at 94k mikes was somewhat caked with grey material. Anyway this 6l80 failed at 112k miles.
Attached is what the pan looked like when I ripped it out at 112k miles.
Hoping this goes smooth and will keep you posted Wednesday night or Thursday. Just sharing.
I'd be interested in hearing about your experience with the 1800-2000 stall everyday drivability after installation and testing.
Thrust
ICT
Wow the fluid with only 20k miles looks nasty. Did it smell burnt or anything? But I guess if the 4-5-6 clutch was toasted that would explain it?
U
usaf27
Yes it smelled burnt. Not sure why it went out all of a sudden. I was just cruising at 60MPH and it started shuddering and slipping. No warning or anything.
NickTransmissions
Sin City
The transmission bench
Yep, 4-5-6 and 3-5-R packs burn down quick once they start to go and transform the fluid to what you see in that pic. I always recommend the 3-5-R apply ring and 4-5-6 piston kit on overhaul as both add one more clutch and steel plate to each respective clutch pack, increasing carrying capacity by 20-25%...
U
usaf27
Completely normal, to be honest.
Are you doing your own fast adapt relearn?
That’s something I’m going to figure out. My plan is to install the trans, load the Diablew tune and then trigger the fast adapt relearn before the first test drive. My father in law has something similar to those Autel diagnostic tool scanners.
You have any insight on any specific way to trigger the fast adapt relearn or an order of operation?
Thanks!
NickTransmissions
Sin City
Thanks!
Insight: Need a bi-directional scan tool or software capable ofnfast adapts and it needs to be performed once fluid level is correct and trans temp is 160+. Beyond that, just follow the instructions as they appear on the scan tool. I use Snap On Verus but any tool with adapt reset functionality will work.
ATRA F/A Bulletin 1392
OReilly Auto FA Fact Sheet
U
usaf27
@NickTransmissions
Test driving after getting it all together. When cruising at 60mph in 6th gear, The RPMs seem to pulse slightly on the tach. In your mind, Would that indicate a converter problem?
Thanks.
U
usaf27
Well the test driving didn’t go as planned. I put on about 50 miles of testing. It appears the converter is having an issue. It acts like it doesn’t want to stay locked up. It has shuddering and what feels like slight slippage. This occurs in all the gears and at any speed. I will be ripping it back out and returning the Circle D converter. Most likely finding another brand of converter too. This will set me back another couple of weeks.
U
usaf27
I just got off the phone with Circle D. They said the problem is with the TCM tune. They mentioned the TC needs more PSI than what a stock converter requires. Does that make sense to anybody?
NickTransmissions
Sin City
Hmmm...Was that mentioned in their literature or whatever paperwork came with the converter?
I'd look at having a tune done in general for the trans and see if the line charge to the converter can be increased but I'd prob want to know why the stock charge is insufficient (ie what about their converter construction, parts etc requires a tune for proper function).
U
usaf27
I did not see any anything in their literature about needing a tune.
NickTransmissions
Sin City
Id get some more details/context from Circle D...It may also be worth consulting @BlackBearPerf about purchasing a comprehensive tune for the transmission...There's a few things mechanically that can be done to improve shift feel/quality but most of that is cared for via a powertrain tune. I admit that I'm largely clueless when it comes to the tuning / programming side of the house for transmissions as I let SMEs in that space handle things...
U
usaf27
Makes sense.
Just sucks because I have already spent money for a Diablew tune. I dont think Lew can adjust (waiting email confirmation) the needed parameters to fix this.
So now I need to decide if I want to invest in HP tuners or rip out the Circle D and go with a more factory like Converter.
BlackBearPerf
Supporting Member Supporting Vendor
Coeur d' Alene, Idaho
We appreciate that. We would be happy to go over the benefits of tuning the transmission and more.
HeavyHoe03
