2007 Yukon, Engine shaking, service stabilitrak + traction control, flashing engine light.
Yukongolds
Was taking a sharp turn in an on ramp last week and coming out of it the flashing engine light, service stabilitrak, service traction control, and check airbag notices all went off. Engine is shaking and and jerks when shifting into drive. No overheating or apparent misfire or lifter tapping noises. Cant see well enough to be able to tell if the engine mounts are broken or not. It does have 230,000 miles on it but otherwise well maintained. Dont really know anyone mechanically inclined so I came here. Just looking to discuss possibilities of what may be happening.
Geotrash
Dave
Richmond, VA
Classic symptoms of a bad ground. Check the ground wire that attaches to the front of the passenger side cylinder head. Check the battery cables also. They corrode internally and look fine to the outside, but playing with them (or subjecting them to high Gs) will release the Kraken.
Welcome to the Forum from NH.
Pics of the truck, please.
Airman68
Kaukauna, WI
Any resolution on this one. Had the same issue on my 2008 last weekend. Stopped and shut off the truck, restarted and it cleared. Did that twice and got a misfire on cyl 2 but I figured that was due to some other issue otherwise the thing runs perfect. I know I have had other GM products in the past that would have a similar issue and it turned out to be a bad accelerator petal but not sure if this is the case here.
intheburbs
SE MI
Again, multiple seemingly unrelated warning lights are most commonly a sign of low voltage.
Check for loose battery cables
Check grounds
Have alternator and battery tested at an auto parts store.
Airman68
Kaukauna, WI
Ok, how about this, high voltage? I noticed during this episode, my voltage reading was way higher than normal. Like, way past the 14v on my gauge. Usually it hangs around 14v but it seemed a lot higher at that time.
Airman68
Kaukauna, WI
After a bit of research, the voltage thing makes sense. I'm going to replace my alternator tonight. It's been making some noise anyway so a little preventative maintenance wont hurt. Will update in a few days.
Marty_S
Hit a bump in turning, 03 YukDenali, 2 messages rotating on dic, Traction control disabled and Stability disabled. So I told it to call my VA shrink. OnTrac said, "Pay." Sometimes laughter is good. Other times to clear all the computer crud on a car you disconnect both battery terminals, set them down and walk away for 10 minutes. Come back with some electrical tape and tape pos to neg cable ends and leave it over night. Fresh and clean registers through the whole vehicle or call it reset to factory default. Attach and start driving. The first 85 to 100 miles will get all the sensors and stuff sorted out. Mileage will get better, shifts smoother... Then plug in an OBD2 scanner and see if the car is suffering.
Or it was a localized for you EMP pulse cannon?
Towmaster
