Would you buy this?
midwestern
Hey everyone - I'm considering buying a Tahoe and want your advice. I'm looking at a 2015 Tahoe LT with 113,000 miles on it. Cost is currently $24,000 with new tires and new brakes. I have NOT done a third party inspection YET, but plan to. Here's the truck: https://www.smarttoyota.com/used-Madison-2015-Chevrolet-Tahoe-LT-1GNSKBKC0FR705057
I'm thinking about doing an apple car play upgrade and replacing the open cup holders with a "lidded" cup holder upgrade if I can find the parts on ebay. The current center console looks pretty bad the way it is.
Anything I should be aware of on this vehicle? Is 113,000 miles on a 2015 problematic?
Thanks in advance.
Mike
Mike, these first year models had early problems with vibration but after nine years I'm sure it's been fixed by now. They had out of round axle shaft flanges and the roof bows did not have enough sealant causing buffeting problems.
Besides the condenser, these trucks also had thermostats on their transmissions that kept them running at nearly the same temperature as the coolant. This causes most of the transmission to fail by about 100K miles. The remedy is to "flip the pill" or install a new lower temperature unit. The heat causes the torque converter to fail sending clutch material throughout the pump and unit requiring a complete overhaul if not caught soon enough. A factory replacement transmission will have a goodwrench sticker on top of it usually. Check for date codes written with a china marker if maybe someone else rebuilt/replaced it.
price seems ok, but... it is a Tahoe you could pick up a suburban for the same price and have more room
the 2 year service is the selling point if it includes the powertrain then you are good and you can beat on it and if the transmission gives out then you get a freebie
the only thing I question is the 50,000 miles GAP of unknown service
check for rust. if it has rust walk away
when I was shopping around I found a lot of them with inop parts, i.e. windows, locks, switches, functions, etc. check everything before you buy and have them fix it before you sign.
also you can take the vin to any gm dealer and check if it has any "special coverage", special coverage can be things like fuel injectors or etc.
Welcome to the Forum from NH.
Pics of the truck, please.
In my opinion, you can do better price-wise, if you continue your search. At that asking price, I would expect the truck to be in pristine condition.
tooleyondeck
Northwest FL
Welcome from FL!
I think the two main points have been hit, the disabling damage and the 50K mile, 4-year gap in service history. That being said, it's loaded for an LT!
It looks like it has been in Wisconsin it's entire life, so there is a higher probability of rust.
It already has Carplay so maybe you meant installing a wireless Carplay adapter?
As others have stated, the price is high considering the mileage and history, but that's how dealers make their money. KBB suggested a private party value of $22,150 in "excellent" condition and without the damage reported. Retail is obviously a bit higher.
All things considered, if I were in the market for a 2015 Tahoe to keep forever and was not concerned with resale value, I would offer them $22,000 OTD, and start ordering parts for a DOD delete.
M
midwestern
Wow good stuff. Thank you for being thorough.
If it doesn’t have a good wrench sticker then what?
not sure where you are all expecting to find "better prices & better condition" from?
have any of you shopped for one lately?
maybe you are looking at private party cash sales? (even those are generally more)
anywhere on the west coast that is a pretty decent price and a 2 year warranty on top and that would be rust free over here.
that price would also be rock bottom with questionable service history and likely no warranty, anything cheaper has many more miles
Well, the lack of the Goodwrench sticker probably means that it is original still. If so, you are probably on borrowed time before it requires replacement. If you are the proactive type, you might consider replacing the torque converter with a new one with a billet housing and thicker clutch material. But first verify that has not been done already either through service records or visually. If you poke around this forum you'll learn how to do that and what to look for.
M
midwestern
For a truck with that had disabling side swipe damage.. I think its over priced.
Truck is best condition I’ve seen out of the 5-6 Ive looked at. No rust and not a blemish on the paint.
Disabling is up to police report which could be exaggerated?
Seems high..I'd extend your search out maybe 200 miles on autotrader or cargurus and see if there are better deals.
In my area (at least) anything under 100,000 miles is about $35-40,000 currently.
I did find a 2015 LTZ on Carmax for $35,000 with 65,000 miles.
Silverado4x4
When it's listed as disabled in the officers report that means a flatbed is dispatched to remove the vehicle from the accident scene, no way I would buy that vehicle.
M
midwestern
Agreed. This is overpriced but in today’s market it’s a steal.
M
midwestern
Welcome from FL!
I was under the impression that CarPlay wasn’t added until 2016
tooleyondeck
Northwest FL
I stand corrected, 2015 Tahoes do not come with CarPlay. My 2015 Camaro didn’t have Carplay bc it had the old MyLink OS and my 2016 Silverado did have it, so I assumed that it was implemented with the new OS but it looks like they updated it in 2016.
91RS
GA
Do not buy a 2015. If you can’t afford an 18 with the 10 speed and a Mac Daddy Platinum extended warranty, pass on this body style.
Craddock
My wife's Tahoe was a rental before we bought it. 2017 model. Had both the AC condenser issue ($700 if I remember right) and the transmission just went out at 111k miles. That one was over $5000.
I would not buy one of these body style again without proof that both of those issues have been fixed. Even with that, the AC issue is coming back 5 years later.
General Fodder
