Knock sensor P0328
jetson22
Hey I am new to site. I recently purchased 2013 Denali XL with 6.2L. It has been hesitating (basically running like crap when at 1500rpm or less). It threw P0101 and P0328 codes. I cleaned the mass airflow and the throttle body. It ran great for a day then the P0328 came back and with the same symptoms. So I replaced the bank one knock sensor, cleared the code. Took it for a spin and all was good. The next morning I used the remote start and it did start but shut off and P0328 reappeared. Any help appreciated.
Geotrash
Dave
Richmond, VA
Two questions: Did you use an OEM GM sensor? And did you replace the connector at the same time?
J
jetson22
Thanks for the reply. I used a Carquest sensor and did not change the connector.
J
jetson22
There seems to be quite a bit of discussion on oem or not?
Welcome to the Forum from NH.
Pics of the truck, please.
Yes, there are issues with aftermarket parts on these trucks. Some aftermarket replacements work well, but others don't. Sensors seem to be an item where OEM parts are strongly recommended.
Geotrash
Dave
Richmond, VA
Ok, so oem are you referring to AC Delco and Delphi?
AC Delco from a reputable supplier like Rock Auto or your local GM dealer, and *NOT* Amazon or eBay - they have known counterfeiters selling there. In the meantime, get a good look at that connector and the wiring. You may want to clean up the connector with some electrical contact cleaner as well. I'm 75% sure you'll find an electrical wiring or connector fault as the root cause. The other 25% is not using an OEM sensor.
J
jetson22
Thx for the reply. The sensor is in a bad spot to get to. I did spray electrical cleaner on it. I suck at electrical issues. I do have a multimeter. How can I check it?
Geotrash
Dave
Richmond, VA
There isn't an electrical troubleshooting guide for that circuit that I can find, but I would be primarily concerned with tracing the wiring back to the ECU physically, and looking for any places where the loom is cracked or where the bare wires are rubbing against mounting points, or where there is missing insulation from the wires.
J
jetson22
Ok I dug into it tonight. It could very well be the wire or the harness. The problem is access. The wire from the harness is wedged between block and whatever. Anyway there is not enough slack in the harness to be able to get my hands on it to check. Also since it is wedged I can’t wiggle or move it to see where it goes? Man what engineer thought that it was a good design. Any help out there?
J
jetson22
Anyone have a pic or diagram of where the bank 1 knock sensor harness leads to?
tooleyondeck
Northwest FL
Just be glad it's not a GMT800 lol
Your knock sensors tie right into the main wiring harness, so if you want to trace the line to the ECU you will need to cut a lot of wire loom to track it. I would start with AC Delco sensors first.
You could always tune out the error codes, if you like to live on the edge...
J
jetson22
Thx for the reply. Does anyone know the part number for the AC Delco harness? RockAuto doesn't carry it. On their site it says the AC Delco sensor mates with PT2652 but when you look that up it says doesn't fit your vehicle. RockAuto carries a Standard Motor Product brand of connector.
J
jetson22
Sorry for late update. The place or person that did previous maintenance on the vehicle did not do a good job. The motor mount was replaced but was not tight and they pinched the knock sensor harness wire. I installed a new one and now that problem is solved. Thanks for all the help here!
Charlie21ny
