Vibration while braking
Mishal
Hi guys
I changed my brake rotors and pads with AC Delco but till now while braking I get crazy vibration. Any thoughts?
Thanks
Hoesgottaeat2
Western NY
Hi guys
Thanks
Does the "crazy vibration" you speak of happen at all speeds when braking?
After replacing the front brakes and pumping the brakes to "normal pedal", did you spin each front wheel by hand to assure you don't have a caliper hanging up or dragging?
Some super cheap rotors out there can be warped or out-of-round right out of the box. Even the "cheap version" of some top name brands can be suspect of that sentiment.
B-train
I agree with @Hoesgottaeat2 in what he stated......used to see it quite often in the repair business. Then it got better for awhile, now they must be cutting costs again. Pathetic
Also, if you reside in a salt state, you may have rust buildup on the face of the wheel bearing hub. If that's not chiseled/filed smooth, it can cause issues with the rotor not sitting true and causing braking issues.
Hoesgottaeat2
Western NY
Good point @B-train. It can get so bad that the ABS sensor doesn't read right and you'll get low speed pulsations from the anti-lock. This can be annoying and down right dangerous when coming to a stop.
Can also be a symptom of a failing wheel bearing.
GMT800 2005 Tahoe Z71
Navy Supporting Member
You didn't say, that I saw. Did you do all rotors and pads or just one axle? If just one axle, could be the other causing the vibes. Plus, what has been said about the rotor mount area is important to check and repair as needed, especially in salt road states. I used to see it ALL the time in KC, Mo. Are calipers moving freely and is hardware installed correctly? Soooo many things to consider.
Hoesgottaeat2
Western NY
Since the OP is here in the '91-'99 section, I'd say his rear axle is likely drum brakes. We haven't approached that subject here yet LOL.
Ok, he can drive the truck and apply the park brake, slowly, to see if has the vibes. I have seen the vibes caused by out of round drums and shoes problems, such as hold down hardware....etc. Sorry, did not look/see the '91-'99 section.
Eman85
Try this, you will be isolating the rear axle. In a clear parking lot or on a road where you have plenty of room and no traffic. Hold the parking brake release and apply the parking brake slowly and feel for a vibration.
A brake job is a lot more than just installing parts, especially on a 20+ yo vehicle. The hub where the rotor sits against must be cleaned of all rust so the rotor sits flush. The calipers must slide freely so all of the hardware must be removed from the caliper, cleaned and lubricated. If the caliper doesn't slide freely everything gets transmitted to the spindle and into the brake pedal. Honestly on an older vehicle I am doing a brake job on I look at replacement of calipers and hoses.
Also on an older vehicle it's very common for the rears to not be functioning properly from neglect and all of the braking being done by the front which overheats them. I throw wheel cylinders away and install new when doing rear brakes on older vehicles along with the springs.
bladenbullet
If it's 4 wheel disk it is likely he has drum in hat parking brake which will do nothing to isolate a front/rear brake ussue...I'm curious...have the tie rod ends and ball joints been inspected?...
scottd
