I see you're slowing down.well here's mine, kind of noisy
SHHHH. I am but had to do a test runI see you're slowing down.
I cannot see any settings you've set for yourself or anyone else's personal settingsHey @07Burb I'm not seeing this thread in the sticky section but its there when I log out. Can you see if I've somehow blocked this thread or something?
All I know is it's still stickiedyou make all my settings stickyI cannot see any settings you've set for yourself or anyone else's personal settingsAll I know is it's still stickied
He aint seen nothing yet. I'm gonna beat that. He keeps daring me. I had her up to 60 today in a 45 with the AC on and 3-4 grand on the tach on shift points. Just getting warmed up.I see you're slowing down.
Living dangerous PawPaw! I'm still impressed with myself for going 78 in a 15--and no ticket!He aint seen nothing yet. I'm gonna beat that. He keeps daring me. I had her up to 60 today in a 45 with the AC on and 3-4 grand on the tach on shift points. Just getting warmed up.
@randeez , you keep him sexually occupied, and I will lure his labs with t-bone steak treats and belly rubs.![]()
Paw Paws guarding against Paw Paw?
I replaced mine with the spohn boxed control arms, def not looseNeed some info/guidance.
Trailing arms on the NNBS Suburban.
Driver side is tight, makes no noise.
Passenger side (see video) is making a little rattling noise that can be moved by hand.
Anybody have this happen and possible fixes?
@DoubeleiveI replaced mine with the spohn boxed control arms, def not loose
Pardon Our Interruption...
www.ebay.com
I am in Cali so no rust here, but I replaced mine just because I wanted a better design. the old ones came out no problem. I do not remember if I used thread locker or not but I assume I probably used the blue stuff, they have not come loose I get under it and re-grease them once in a while.@Doubeleive
Thx the reply.
I was figuring a replacement might be in the cards. Funny how you see trailing arms or control arms listed for that part.
Why did you replace yours?
Did you have any trouble getting the bolts loose on each arm?
Did you have to heat them up, PB blaster or big breaker bar?
Did you thread locker the bolts when you replaced them?
Was about to post the same. Had them on my ‘07 and enjoyed themI replaced mine with the spohn boxed control arms, def not loose
www.ebay.com
Thx man.I am in Cali so no rust here, but I replaced mine just because I wanted a better design. the old ones came out no problem. I do not remember if I used thread locker or not but I assume I probably used the blue stuff, they have not come loose I get under it and re-grease them once in a while.
for the uppers I think I used the mevotech stamped steel which are basically the same as oem, I just painted them red to match the spohn. so I would not bother with the uppers unless they are worn out.
