Problem with lowering springs
mikev04
What’s up everyone this is my first post, happy to be here. I just installed an eBay no name 2/3 lowering kit on my 04 Tahoe. Drop spindles in the front and shorter springs in the rear with shock extenders. The front install is all good. My problem is the rear springs seem too short. When the rear end droops, they’re loose as a goose ready to fall out of their pockets. Shock extenders are installed with stock style Bilstein 4600s. Truck sits exactly how I want it and handles good (still needs an alignment). I’m wondering if anyone else has experienced something like this. I’d imagine it would take a crazy scenario for the rear end to travel that much in normal driving conditions, but it sketches me out that it’s even possible. Any input would be appreciated.
Welcome to TYF!
It's probably the coils. Better coils are designed to be longer, but still provide the same drop, or thereabouts. It may never be a problem, but you don't wanna find out the hard way. You might need to get drop shocks. They're shorter so they'll max out sooner, hopefully before the rear is totally unloaded. Have you gotten shorter sway bar end links? If the coils are just barely to that point of falling out, shorter end links would limit the rear's droop a little. You might need to get the offset links, anyway. Until then, no ramping. Then there are limiting straps like trophy trucks have...
mikev04
mikev04
Welcome to TYF!
Thanks for the reply. I’ve seen the eibach springs and a few other brands. They all look way longer with the elongated pigtails that are designed to compress to the drop height but not fall out when the rear drops. I’m running stock end links. I suppose aftermarket links aren’t a bad place to start. Especially since you’re saying I probably need them anyway. I’d like to keep the bilsteins because they weren’t cheap and they match the fronts. So maybe I’ll buy another pair of springs with a better design. I don’t want to kill anyone over a couple hundred bucks.
Edit: do you have any sway bar links or spring recommendations?
Welcome to the Forum from NH.
Pics of the truck, please.
For maximum effectiveness, the sway bar should be parallel to the frame (or ground- close enough) with the vehicle resting at ride height. Lowering it puts it at an angle, reducing its leverage. Sure, it's likely nothing you'd ever feel. But, in your case, it might benefit you more than to just restore the proper geometry. Also, I was alluding to the offset links offered by DJM or these. A 3" drop is kinda on the cusp of where you start to have interference problems. At 3" or more than 3", the RH "arm" of the sway bar hits the bolt on the shock mount. The offset links are shorter to correct for the drop but also shift the sway bar to the right for clearance.
Since you have good shocks and they're beneficial otherwise, I'd try the links first. They wouldn't be a waste even if they didn't completely solve your issue.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
I have the $150 ebay 3" rear drop kit. Mine would wiggle around a bit at full drop. I ordered new top and bottom isolators and that snugged them up good enough for me.
mikev04
mikev04
Thank you everybody for your responses. Turns out the Bilstein shocks I ordered (PN 24-143806) are 24 inches long full extended. With the shock extenders, this allowed roughly 22 inches of length when fully extended. I needed about 20 for the springs to stay in their pockets. I ordered Belltech rear shocks (PN 2410FF) and their extended length is advertised at 19.5 inches. I ran these without the extenders and all is good in world. Had I ordered stock length shocks (I think they’re about 22 inches fully extended), I could have used the extenders and had no problem. You live and you learn, I hope somebody can get something from my mistakes.
Edit: Forgot to mention I’m definitely going to invest in some shorter sway bar links. iamdub schooled me right, the rear bar is sitting at a funky angle.
mikev04
mikev04
Here’s a few pictures of the truck. Going to get this thing aligned tomorrow and tear up some pavement.
Here’s a few pictures of the truck. Going to get this thing aligned tomorrow and tear up some pavement. View attachment 409403View attachment 409404
I've been MIA for a few days. Is it lower in the back? You have to put some miles on it to let the new springs settle. If it's squatting, you can adjust the front for free by turning the torsion bar adjusters. This is where measuring each corner comes in handy. GM vehicles are often lower on the driver side. Having the type of suspension yours has, you have the ability to easily fine-tune it side-to-side. If you're satisfied with the way it sits and have already gotten the alignment, disregard.
89Suburban
SE PA
I don't understand how I read all these posts about drop kits and springs on this site and the web, and no explanation on how to keep the rear drop springs snuggled into place when put on a lift. I just installed 4" drop springs tonight and it was a major PITA settling the weight down and making sure they lined up into their seats properly at the top.
I can not imagine taking my rig into a shop and getting lifted up to have the tires balanced or some other work on a lift and the rear springs and isolators falling out of place easily. This really has me upset. I have to be able to have this lifted off the ground by some schmuck at a regular shop without worrying about this.
Usually, shocks that coordinate with the drop are what limits the droop.
JamesinAbilene
