2022 Chevrolet Tahoe stealthbox and center dash speaker addition
Mhale8999
I have the 2022 Chevrolet Tahoe RST. It does NOT have the center dash speaker. Is it possible to add that? I’m not sure if it’s possible or what would be required to do so.
I’m also interested in adding the stealthbox and was wondering if anyone has done this yet me can pass along any advice or considerations. The price of the stealthbox is just crazy and considering you have to add an amp and re-wiring,mi wanted to get your device before jumping into this.
‘’thanks for taking the time to reply, really appreciate any input you can give me.
Welcome to the Forum from NH.
Pics of the truck, please.
I haven't ever used a stealth box, and yes, they are quite expensive. Do you have captain's chairs in the second row? If yes, you could put a removable sub in the space between the chairs.
BrokerThis
'22 Denali Dmax
Detroit
Go the escalade box instead of stealth.
Stonebx
Bronx, Ny
Hey,
Just seeing your post and wanted to provide some information. Hopefully it helps. If your 2022 has the grill on the dash then more then likely you can add a speaker. However, considering GM's audio set up it makes things difficult upgrading or adding to your system without having to bypass the factory amplifier. You can but then you stand to lose some of the factory features that are tied into your infotainment system and it definitely will cost a substantial amount depending on what manufacturer you chose to use. Personally I kept all my bose speakers and replaced the subwoofer with JL Audio's stealthbox and added the JL amplifier and it not only improved the bass tremendously but even my door speakers sounds better. I am considering to replace just the door speakers at some point and add another amplifier but at the moment it sounds great. I'd definitely recommend going to a reputable shop. They know how to bypass the factory amplifier without any issues. Unfortunately No one else is making a stealthbox at the moment.
BigRedRST
Just ordered the Escalade box, 180 shipped. Probably should have purchased locally but time is money.
shevlini
Very interested in your results. I am looking at a 22 Z71. When you get the box, do you mind measuring the depth? I can then do some Sub shopping ;) I will assume my JL 10w3 will not fit (6" depth.)
DenaliXL2022
I am interested to find out how this worked out for you. Is the box built well enough to handle a true sub rather than the garbage GM put in these boxes to begin with?
LDJ87
I am looking for the post where someone installed the Escalade box. Has anyone done and cares to elaborate?
porschegregg
I bought a 2021-2023 oem rear bose subwoofer box part number #84776627. It is 4 inches deep where it molds to the gas filler neck inside the fender. Then it tapers up to 5 inches deep. I purchased a Kicker comprt 2-ohm 8-inch subwoofer with a mounting depth of 2 11/16 inches. I am powering it with an Audio Control amplifier — 300 watts RMS x 1 at 2 ohms. I picked the amp because it is small and the RMS wattage matches the sub, it also has an internal line output converter.
porschegregg
Hey,
View attachment 419093View attachment 419095View attachment 419096View attachment 419097
porschegregg
Hi,
The oem box used an 8 inch subwoofer. You could make the hole larger. The internal box depth is split half 4 inches and 5 inches on the other half.
RJStanford
Hey,
Where did you mount the amp for the sub? I’m hoping there’s a good hidden space that works.
jpurdie
