Overheating transmission
StephenW
2015 -Yukon XL Denali with 190k miles. Transmission overheated 2 days ago. Changed out the fluid and filter (overdue). Nothing remarkable on the magnet or in the fluid - just dirty.
Just drove it after the change out and temp was 225-250 and rising in 25 min of driving. Am I just screwed into a transmission replacement?
tom3
Does this year have the thermal control valve on the side of the transmission where the cooling lines connect? That could be stuck or plugged somehow.
S
StephenW
Yeah unfortunately I am not savy on the system. I would love a diagram to see how everything flows and what could be a fail point. Like - is there a TXV or thermostat that could have failed?
NickTransmissions
Sin City
The transmission bench
Cooler Bypass Valve aka Thermal Bypass Valve aka Transmission thermostat.
Check out the Tech Svc Bulletion if you havent see it already. There's an updated CBV from GM but it simply lowers the temp the thermostat begins to open. Id rather delete it all together...
CMoore711
Do you have the 8 speed or the 6 speed transmission?
190K miles just changed fluid a few days ago… How often was the transmission fluid changed for that first 190K miles?
Marky Dissod
Just drove it after the change out and temp was 225F-250F and rising in 25 min of driving.
Pretty sure 6 speed. Not very frequently.
More like aged into a transmission replacement.
Regular Production Order 'MYC' = 6L80E
If your Service Parts Identification sticker lacks that particular three-letter code, you've an 8L90E (8L90E RPO code escapes me).
arkie
M5U or M5X should be the 8L90
scottd
