2021-2024 LED Tahoe Tail Light upgrade
HollerToHighcntry
Hey guys, I made this video because I wasn't able to find much on replacing the crap filament bulbs. I ordered and tried a multitude of LEDs, this is what I found to be the best and cleanest. Hope this video helps cut down on your research and install time.
PARTS I USED:
Load Resistor (6) -!Follow Manufacturers Directions!- https://amzn.to/44r7Cjo
3m waterproof connector https://amzn.to/3sya5uT
Tahoe reverse LED https://amzn.to/3OMn57T
Tahoe break LED https://amzn.to/44roPt1
Tahoe turn LED https://amzn.to/480oRev
Blueinterceptor
How hot do those resistors get. There is a forum member here that made a harness which direct connects to the harness outside of the vehicle. But as I understand it, the resistors get pretty hot
HollerToHighcntry
HollerToHighcntry
That's great. Thank you. I still can't figure out why in 2023 GM is still using incandescent bulbs. I get angry every time I walk past the rear of my Tahoe.
I felt the same way.
How hot do those resistors get. There is a forum member here that made a harness which direct connects to the harness outside of the vehicle. But as understand it, the resistors get pretty hot
Ive seen these instances as well. Which is why I went with bulbs that have a heat sync built in. I used my temp gun and only got a 40 degree+ difference from Baseline after about 10 minutes of constant on use. My base was 110 (AZ) and when fired up the lights under heavy use it got to 160max average reading was 150.
Larryjb
I'm actually glad that they are still using incandescent bulbs. If these new LED housings get damaged in any way that is not covered by insurance or warrantee, they can cost thousands to replace.
Imagine you have a 10 year old truck with one of these housings and the plastic develops a crack, and it fills up with water shorting out all the circuitry inside. I'll take the simple incandescent housing.
But that's just me. I'll run back to my igloo now.
Blueinterceptor
I know you said that you didn’t burn any plastic, did you warp any of the housing or melt any of it that contacted the housing. That seems pretty hot for a confined space.
HollerToHighcntry
HollerToHighcntry
Nah, there is a lot of room back there. I’m pulling. +40
Just pulled it out and let the blinker run for a few mins, way longer than would happen in real driving. We are well bellow the mould point of the plastic used in the lights. Again my case is extreme. I live in a already very hot desert. See pics.
ZKWBQD
I found the LED tail lights to be too bright. People were often flashing their bright lights at me or otherwise trying to get around me. I went back to the factory incandescent bulbs.
HollerToHighcntry
HollerToHighcntry
………uhhhh what. Specify what bulbs (break or blinker) and what brand and lumens that was causing people to flash their lights from the rear. Driving normally caused this??
Larryjb
I find many of the LED lights too bright as well, whether they be brake, blinker, or headlights. I don't flash my lights at them because I know they have no control over them.
peyc2
New York
Hello,
Can you tell me where you finally bought these light?
Thank you,
HollerToHighcntry
HollerToHighcntry
I would advise mounting the resistors on the body behind the housing, eventually they will melt the wiring, will take some time but eventually it will.
speaking from experience.
Floated the break resistor. Spent 1.5 hrs in bumper to bumper traffic. No melting… so far.
HollerToHighcntry
HollerToHighcntry
Takes time, it's not going to melt right away, might take a year. it was just a suggestion take it or leave it. I didn't think mine we're getting hot either but found out otherwise later on down the road
I’m taking it for sure. Thank you.
worleytrev93
