2016 Yukon XL Denali 6.2l battery question
PA-WOODCHUCK
Anyone know the AC delco OEM battery group, CCA, and AGM or not? I'am trying to avoid almost pulling it out to get info... so I can properly test it?
thanks
thanks
should be a H7 800-1000cca
couldn't tell you if it is agm or not, usually you can tell by looking at the design of the battery
Onlyone
New Mexico
Buy a good battery. Here’s what you need.
P
PA-WOODCHUCK
I'm sure it's a good battery, but not $350
P
PA-WOODCHUCK
Here's what I found group 94R and H7 for AGM. That said if mine is 94R it tests good, but with AGM setting shows replace. I did both set to 800CCA. Standing voltage is 12.7v
Costco sell's the Interstate AGM's for right around $160-180.00 I have 2 in mine and they just outlasted the Odyssey's I used to use for twice the price
P
PA-WOODCHUCK
Walmart has the H7-AGM with 4yr replacement for $180 which is about $80 less than big box auto parts stores. and they only have 3yr replacement!
SpyShops212
I bought the Delco Gold battery 42 month in 2/2022 for $220 and it failed while I was away on a Saturday on 12/2022 where I was 300 miles from home. I did not want to keep calling OnStar or look for a jump every destination I went too and wait until Monday and risk damaging my computer or something else. I also did not want to drop off my truck and leave it for a day or two at the dealer for a battery or wait 5 hours at the dealer. So I went to AutoZone and purchased an AGM platinum battery which I changed myself in 15 minutes using the tools at AutoZone. I lost out on $220 but I learned my lesson. It is easier to go to any AutoZone in the country and give my phone number & they will replace my battery under warranty or prorate it. The battery comes with a 3 year warranty. The AGM battery is better because if your like me and always clean your truck where you drain power then charge the battery then AGM is better for you. They said AGM will last twice as long.
duke90
Corona, CA
I just replaced the battery on mine a month ago...seems like 3 years is all im getting out of the battery on these trucks. OEM battery I had to replace in 2020. Replaced with an Interstate that also lasted only 3 years. This time I just went with AC Delco Gold Standard from Autozone for $210. The batteries in my old R50 pathfinder use to last me 6-7 years..barely getting 3 on this truck is a bummer
justafarmer
