6.6 Gas L8T Engine Swap in 2015 Suburban
PG01
Up here to the right
Didn't look like there was anything wrong with it. Was it a totalled truck? The donor had 6 miles on it?
Maybe you should've gotten the cluster too--in case you have a problem getting your stock cluster gauges to work.
‘I know wuts wrong wit it…. Ain’t got no gas in it….ummmmhmmmm’
L8T BURB
L8T BURB
Kentucky
So here's the story on this...
The seller is out of Michigan. Schram Auto Parts. They have this truck, and about 20 or so GMC Savana 3500 and Chevy Express 3500 Cutaway cab/chassis vans. There was a fairly significant train derailment at some point, and GM filed these on their insurance. With any suspected frame damage, these could not be legally be repaired and sold. Leaving scrapyards and other wholesalers in the area scrambling to buy them to part out.
The seller has a 99% rating on Ebay, and everything seems 100% legit at this point. Fingers crossed for a successful install!
Marky Dissod
The hardware part of the install will not require any crossed fingers.
The hiccups / burps / etc will be with the software, but they are FAR from insurmountable.
Once the kinks are ironed out, you'll make EVERYONE wonder why GM isn't making the L8T more available.
Tiki
Glad this kind of swap is still going strong in 2023 !
mattbta
Frisco, TX
I bought some e-fans from Schram. They accepted my "offer" on eBay and item was as described. They're legit.
minytrker
I didnt read every post...but you can the 6.6 on the factory ecm. I just tuned one swapped running on the E92 ECM. Its a nice upgrade over 5.3.
L8T BURB
L8T BURB
Kentucky
This is very promising! May I ask which vehicle you swapped the L8T into? The 6.6 I am swapping comes fully dressed with all accessories, so I am hoping to maintain as much of the new stuff as I can. I was however, hoping to maintain my stock E92 ECM, as it seems using the 6.6 ECM (E93) could prove to be a bit more challenging.
Schram emailed me and stated there were some heavy tornados that they dealt with Thursday night, leaving much of the area without power for the weekend. Slight delay in them shipping the engine to me. Looking at an end of week ETA as of now!
L8T BURB
L8T BURB
Kentucky
UPDATE!
Engine and transmission delivered earlier than expected! Delivered by Dayton Freight. A++ job on the palletization and overall packaging! This thing is a MONSTER! 10/10 Schram Auto Parts...HIGHLY RECOMMEND! My technician states he may be able to get started on it by the end of the week!
RB_Trucker
Redondo Beach
My question is. Besides, the electric power steering and mechanical fan wouldn’t dropping the engine in be the same as a Bored and stroked 6.2L? If that’s the case, then it should be a pretty simple swap because all these LT motors are just like the LS series, where the exteriors are pretty much the same, casting wise and sensor location wise. I like this thread because when my 5.3 needs rebuild I might go this route instead of a 6.2.
L8T BURB
L8T BURB
Kentucky
From my understanding...yes you are correct. A stroker 6.2 without the DOD/AFM, and is designed to run on 87 octane while making more HP and TQ than the 6.2. I am told that I should be able to discard the mechanical fan and use my stock electric fans, and same with the power steering. We shall see!
L8T BURB
L8T BURB
Kentucky
Anyone have insight on whether I would be able to maintain the 6.6 belt driven components? Such as a/c compressor, alternator, and water pump? I would feel better using the 6.6 stuff as opposed to using my 186k mile stuff from my 5.3. The new 6.6 came fully dressed with all belt driven components attached.
B-train
I would think it would work as recieved. My question is how are you going to work around the PS pump delete? If I were doing it, I would see if a steering rack from the 7-14 would bolt up and then use the power steering. That would make it so the belt could stay as recieved, then just leave the mechanical fan off and use the E-fans.
jk6062
