Service 4wd light?
JF91
I have a 99 gmc yukon, Service 4wd light is on the dash cluster and all the 4x4 switches are lit up solid including the neutral. No switch activity. I replaced the transfer case shift motor and still the same. Any ideas? Thanks!
Wolfpackfan21
Just fixed this on mine. It was the switch itself. $20 part on Amazon. In my situation the buttons had cracked from age and it was dust/moisture getting in there that caused it to go bad. Funny thing is I had bought a replacement switch just because the old one looked like crap but had it in a shop to get the 4wd looked at and this was the solution ended up costing me $150
the 18th letter
Northern New Jersey
I think this may be my issue. Light started coming on the dash Sunday and happened to have a good scanner handy but no codes. My switch has been been blank off and on for a while now so I should have already replaced it :(
You'll need a scanner that can read the transfer case codes. A cheapie reader won't.
johnsonwillie199
