Sparksalot
Bastrop County, Texas
installed the roof rack cross rails, the wireless android auto adapter, tightened up the rear view mirror it was wobbling a bit.
got a replacement drivers door switch on the way one of the window switches is sticky, superchips programmer should be here today.
and the transmission thermostat delete kit should be here today or tomorrow
I had done the lower temp tstat originally. I'm still not satisfied though, so have the delete kit on the way as well.
it's always too hot around here to just lower it, even in my 12 with a deep pan and tru cool and dead of winter at 4000ft snowing it only got down to 100, i guess if we lived up in nebraska it might need a bypass but not around here
a guy has these for sale locally and say's they came off of a 2020 suburban, but they don't look like they bolt up the same?
****never mind, i'm goofy after looking a little more they look right
they kind of look like z71 running boards but can't find any online that look the same
Programmed it with the superchips f5, turned off the limiter and afm used there trans tune. This has the 5.3 so it should do around 136-137 now took it up to 115 to verify but not enough runway to get anymore out of it, the f5 allows tpms adjustment by the way. Also allows you to adjust the throttle response like a pedal commander
Picked them up for $80 OEM z71 running boards
Sparksalot
Programmed it with the superchips f5, turned off the limiter and afm used there trans tune. This has the 5.3 so it should do around 136-137 now took it up to 115 to verify but not enough runway to get anymore out of it, the f5 allows tpms adjustment by the way. Also allows you to adjust the throttle response like a pedal commanderView attachment 406969
Can you adjust the fan turn on settings with this one?
SpyShops212
I have silver roof racks for sale.
SpyShops212
Got my $30,000 thermal night vision and checked out my heated/cooled seats to make sure they was functioning correctly. I found out that when I put the bottom cushion back after changing the foam and leather bottoms that I didn’t clip the rear correctly and it was pinching the blower vent bag that heats/cools the seat. I also like the new foam from GM which is black (pictured) instead of the yellow one that turns orange over the years.
Note: I took my iPhone and took a picture through the lens. It is way better when looking with your eye.
SpyShops212
Can I borrow your scanner for a fee to disable my AFM & speed limiter. If you’re in Houston to close by maybe we could meet up. I don’t want a range device in my odb port. I have the 10 speed which there is no programming for the transmission that I heard of yet. I don’t want to spend $500 just to do those two things.
if I spent $30k on thermal glasses and that's the best they could do I would be extremely pissed, no offense. based on your photo anyway.
SpyShops212
I took my phone and shot a picture through the lens. It is way way better when looking with your eyes.
PG01
Up here to the right
Get an obd splitter then plug in the range and forget about it.
Ps- hate when my odb (old dirty b a s t a r d) port is used too….
I just realized this device will work on both of my Hoes. More added value.
these were the additional options it gave me upon initial setup, 2017+ require ecu unlock
and it should be noted that the 8-speed & 10 speed are most likely not able to be unlocked, depends on the year but I am pretty sure the 10 speed cannot be unlocked at all (yet)
What is the advantage of vin unlock?
these programmers only do 1 vin at a time, you could switch it from vehicle to vehicle as long as you "un-marry" it, a extra vin unlock would allow 2 vins at the same time, not sure how many vins could be used with 1 programmer
well poop, should have checked a little better, the running boards I bought are for a 2021+, no wonder I couldn't find a pic of some on a k2
gm moved the mounting bracket locations of course, length is the same but no way to mount them without modification and it's not worth messing around with.
o'well listed them on offer up.
Dh1280
