2011 running board pads fit. OEM
The Grey Beast
So I posted before on the subject of asking anyone for OEM running board plastic pads. I found the passenger side but Chevy discontinued the the drivers side. Many of you were very nice and gave me links to those on this board to help. Well I ordered the passenger side for the drivers side here is why. The holes are the same for each two pronged attachment. There are side prongs and that’s where things get complicated. I wasn’t sure if the holes would match. Well it did match. So there drivers side pad fits the passenger side and visa versa. The OEM code for the passenger side is 25804637. Good luck tans thank you all.
Ken
Rick Can
Ken
Excellent! I'm ordering the passenger side pad to replace the driver side pad for my 2014 Tahoe Z71. Hope it fits.
The Grey Beast
The Grey Beast
Great hope it works. I’m not sure where you ordered it from but most online want your vin number to verify if it fits your particular vehicle. Hopefully you have a company that offers money back if it doesn’t.
When you remove the old running boards try to remove them without the plastic pegs staying in the hole. You may have to pull them out with pliers if they break. The biggest concern is to try not to put the plastic running boards on the ground they can get easily damaged. Be gentle putting it in as well. Make sure the holes are lined up before pushing it in. Once you believe they are lined up. Push in with both hands and then look at any gaps the the plastic running boards to the metal runner. If you have to push in with the weight of your feet that works too. Just make sure the holes line up. Most of the time you feel it. You may also hear that “click”.
You got this
Ken
hitdawg742
Ken
was it difficult to change out the pad? can you detail the process? is there a video available? Thanks!
The Grey Beast
The Grey Beast
Same here. Nice thine is we use the pads often and they are durable.
Good luck.
Ken
scottd
