Need a new radiator
T
Tamcphail89
OK I'm changing this out tomorrow. How much coolant should I grab at the store?
GM06DEN
GM#22840116 RADIATOR, (CORE SIZE 34 X 17 1/4 X 1 1/8) (W/TRANS & ENG OIL CLR) (ACDelco #21649)
You sir have the oversized radiator
hows it going? Any possible way you can help me find the correct radiator?
Thanks in advance
PG01
Up here to the right
Thanks in advance
If you do in fact have an 06 Denali the art number in this thread is probably what you need and or you can call 1-800 radiator as suggested multiple times on here. I’ll tag Rene anyway but we need minimum last 8 of your VIN.
@915_Tahoe
Sorry Rene, I figured you needed a wake up call……
GM06DEN
@915_Tahoe
Ok the last 8 of my vin 6J119310
thank you I’ll definitely give 1800 radiators a call!
Thanks in advance
there all pretty much the same from 00-14 the only differences are some are thinner or thicker depending on the part number and some have a oil cooler and some do not, you can use one with a oil cooler even if you do not have the lines installed. 34" is standard for all 1500 gmt800 or gmt900 including pickups
some of the older ones had a 28" and a clutch fan but you can even change those to a 34" you just need the larger shroud from a junkyard
the holes in the frame where it fits in on the bottom are all the same and so are the bolt holes up top
that's why aftermarket ones will show 00-14 compatibility, but gm loves to change part numbers so they can keep the money rolling in.
Towmaster
