New 2023 Yukon At4 Order - 6.2L unavailable
StephenPT
St. Helens, OR
As of now, GM offers only the 6SP when mated to the 5.3L. Part of the desirability of the 6.2L is that 10 SP trans.
The 6.2L doesn’t have to lift a finger to get the truck moving. Once moving it doesn’t work as hard using lower RPM based on gearing, hp & torque. The byproduct is also longevity.
It was likely this way in the pre-'21+ generation, but since '21, all engines - 5.3, 6.2 and 3.0 diesel get the 10L80 (ten speed) transmission.
WalleyeMikeIII
Sunny and Snowy Minnesota
The 5.3 and 6.2 both have the 10 speed
petethepug
Michael
SoCal
Wow, Ty. I was looking online last week and all the trans options for the 5.3L showed the 6L80.
That 10 SP will wake up the 5.3 and give it the milage and off the line oomph it deserves.
Gawd I’d love to have a 10SP in my 09 Esky.
Vladimir2306
Interesting that on the 5.3L V8, GM recommends 87 Octane in US, even w/ the 11.0:1 Compression ratio..owners manual excerpt..
What does your owner's manual say?
Regardless, running your 95, you certainly won't hurt anything in your 5.3, there is only positive to be had running the higher octane...but it may not be required and you may not see any benefit.
Unfortunately, I can’t find the instructions online with us, because Chevrolet has officially left Russia. But on automotive sites, the technical specifications for Tahoe 5.3 really indicate 95 brand gasoline. But it's funny, it turns out that our 5.3 owners can fill in our 92nd gasoline without any problems)))
WalleyeMikeIII
This seems to match with what the Owners Manual says and what I would expect.
WalleyeMikeIII
In the pickups, the 5.3 gets the 10L80 starting at model year 2019.
For the SUV's I believe it didn't come in the 5.3 until 2021.
6.2L has had the 10L80 since 2019 in the SUV's and Trucks.
BDM3
Retired back in 2006, so I never got to fly the "K". I actually picked up a brand new MH-53E from Sikorsky so many years ago when we transitioned from the RH-53D to the MH-53E. It had that new car smell in the cockpit. Hard to believe the Navy is now retiring that aircraft. Wow, time flies...
That must of been quite the experience getting to pick up the “E.” Did you pick it up from the Stratford plant? I agree it’s sad to see it getting retired, but the “K” will be a great replacement for decades to come. Trying to get a replacement for the Blackhawks out there too.
Vladimir2306
This is very funny, my friend, the owner of Tahoe 5.3, which he bought officially in Russia, sent his manual. Here is the screenshot. The translation is as follows.
The recommended fuel is
unleaded gasoline with octane
number 95.
Unleaded gasoline with an octane rating of 92 may be used. However
use of unleaded fuel
with an octane rating of less than 95 will result in
to a decrease in vehicle dynamics and deterioration in fuel efficiency.
It seems word for word as in the American manual, but 87 gasoline replaced 95. Despite the fact that the American 87 is the same as the Russian 92nd. It turns out that when Tahoe adapted to Russian conditions, we removed the ability to refuel 92 with gasoline))))))
WalleyeMikeIII
View attachment 406772This is very funny, my friend, the owner of Tahoe 5.3, which he bought officially in Russia, sent his manual. Here is the screenshot. The translation is as follows.
number 95.
Or there was doubt by the engineers that 92 was always >= 92, so they margined it to 95?
RAMurphy
Bob
Military
S. Maryland
Yes, we picked it up at Stratford. Toured the factory too. Great experience. Great thing about the 53 we were able to take all the special equipment in the back of the aircraft. Didn't even know it was back there. We took the river route back through New York and flew circles around the Statue of Liberty. Can't do that anymore after 9/11. Have some great pictures from that trip.
Vladimir2306
Well, then we could generally supply the minimum gasoline with an octane rating of 100))) In fact, we have good quality gasoline at gas stations of large brands. Although the 900th Tahoe was funny. 10 years ago. When using gasoline from one of the filling stations, the engine oil froze completely at a temperature of -5)))) People began to come to the official dealer en masse, because the oil sump is not liquid oil, but like tar. It turned out that this network of gas stations has some kind of additive in gasoline, which, when mixed with GM 5w30 oil, makes the oil lose its properties even in a slight cold. But a recommendation quickly came out not to use this particular network of gas stations.
Saltydog
We have the 3.5 in our 21' and I find it just fine for most everyday driving and the MPG is decent for a V8 land barge.
The only time I find the 5.3 a bit lacking is in passing at speed, it can feel a little bit restricted, almost as if it needs more exhaust flow.
Dh1280
