New 2023 Yukon At4 Order - 6.2L unavailable
vcode
I agree, the 5.3 engine is excellent)))) but not when it is compared with 6.2))) but here is a completely different story. By the way, in terms of fuel consumption, 6.2 is about the same as 5.3))) but 6 seconds to a hundred ... this is WOW))))
6 seconds quicker to 100? Or 0-100 in 6 seconds which is not happening. Fuel consumption may be similar, but the premium required has consistently costed $1/gal more here in WI.
V
Velvet Wheeler
The previous generation to the 5.3L was the Vortec 5.7L, which I'm very familiar with. 255hp. Never saw it as a sluggish engine until...my son brought home his 2016 Silverado a couple years ago. That 5.3L in comparison makes my 5.7L feel like Fred Flintstone's feet are pushing it lol. 355hp in that 5.3L of his I'm told. The 5.3L is a great little eight.
1hp per cubic inch has always been considered a very desirable benchmark for horsepower in an engine. That 5.3L exceeds that benchmark definitively.
That’s good to hear. Id rather have the 6.2, and would have if it was available, but sounds like the 5.3 will be just fine. Thanks for the insight.
Welcome to the Forum from NH.
Vladimir2306
Yes, the 6.2 engine accelerates 0-100 kmh in 6 seconds. While the 5,3 engine accelerates 0-100 in 8 seconds. This is a tangible difference. But personally, I prefer the way the 6.2 engine accelerates from 80 to 120 km/h on overtaking. Well, both of these engines need premium fuel
vcode
5.3 uses regular, at least here in the States....
pa31p
If you put your foot into the 5.3L it has more then enough pickup, many have sold or traded from 6.2 to a 5.3 because of the fuel cost. there’s always a time and aplace where even a 6.2L is not enough power
RAMurphy
Bob
Military
S. Maryland
That’s awesome! I work for Sikorsky and have built some of the newer K models (King Stallion). Great aircraft’s
Retired back in 2006, so I never got to fly the "K". I actually picked up a brand new MH-53E from Sikorsky so many years ago when we transitioned from the RH-53D to the MH-53E. It had that new car smell in the cockpit. Hard to believe the Navy is now retiring that aircraft. Wow, time flies...
WalleyeMikeIII
Sunny and Snowy Minnesota
Hm, its bad, in Russia we uses premium in both of them 5,3 and 6,2.... We think that using regular finished in tahoe 900))
What is your Octane rating on Regular and Premium there...that could be the difference.
In U.S., the 'Octane' rating posted on the pump is actually the AKI (Anti Knock Index), which is the average of Motor Octane Number and Research Octane Number...so AKI = (RON + MON)/2
GM specifies 87 AKI minimum for the 5.3 and 91 AKI minimum for the 6.2 in USA.
Here is a good description of the various Octane Rating Methods used/posted in Europe vs. USA. Note, I don't agree w/ the sentiments in the article that lower Octane Fuel is Lower Quality...it is simply less resistant to detonation under compression than higher octane fuel...whether this matters in a given application is dependent on engine design...but the article does get to how different countries use the different test methods.
Vladimir2306
We have gasoline with an octane rating of 95. We pour it into both 5,3 and 6,2 engines
WalleyeMikeIII
So your 95 is probably RON, which is like 91 US.
Your 98 is like 93 US.
95 probably overkill for the 5.3, but not sure what else you have available, nor what the cost is...5.3 in US model can run on US 87, which is your 91, but possible GM gave a different tune for your market?
Here is a good table:
Vladimir2306
We have gasoline with octane ratings of 92, 95, 98 and 100. In general, we have an opinion to be guided by the compression ratio of the engine: if more than 10,5, then gasoline is 95, if less than 10,5, gasoline is 92. The Tahoe 900, which has a 5.3 engine, had a compression slip of 9.9, so it drove perfectly on 92 gasoline. And the Tahoe T1 with a 5.3 engine has a compression ratio of 11, which means gasoline is 95. The Tahoe with a 6 2 engine has a compression ratio of 11.5. So also gasoline 95. But turbomotors are 98 gasoline, and for sports cars it is gasoline with an octane number of 100
WalleyeMikeIII
Interesting that on the 5.3L V8, GM recommends 87 Octane in US, even w/ the 11.0:1 Compression ratio..owners manual excerpt..
What does your owner's manual say?
Regardless, running your 95, you certainly won't hurt anything in your 5.3, there is only positive to be had running the higher octane...but it may not be required and you may not see any benefit.
petethepug
Michael
SoCal
As of now, GM offers only the 6SP when mated to the 5.3L. Part of the desirability of the 6.2L is that 10 SP trans.
The 6.2L doesn’t have to lift a finger to get the truck moving. Once moving it doesn’t work as hard using lower RPM based on gearing, hp & torque. The byproduct is also longevity.
The Whip
