mirror power cord adapter for dashcam?
tjs3922
Looking for a dash cam and have seen some makes use a Donger power cord that attaches to the back of the powered mirror. Anyone here know if there is a easy to use product like this for GMC? Donger lists every make but GM.
ScottyBoy
Shreveport, La
They probably don't make one for the newer trucks because there isn't an ignition controlled power wire at the mirror. A few years back they started doing away with ignition and accessory wires in the vehicle for the most part. Pretty everything is databus controlled. Basically the computer senda a data signal to tell it to turn on, instead of the ignition switch just turning it on. So you must likely have no choice but to run an ignition powered wire from the fuse block up to your dash camera.
I haven't seen the upper consoles on the 21+ but if there is a airbag light/indicator you can tap power off of that.
Vladimir2306
it seems to me that power can be taken from the control unit on the ceiling, where the sunroof control is
CDONNS
Here is the Mirror connector pinout for Yukons on the 2022, should be the same for the 21 and 23. Pin 2 (Violet) should be your ignition wire at 12V and pin 5 (Black) should be your ground. You would need to step down the 12V from the vehicle to 5V 1A (dashcams are basically glorified webcams) using something like this.
VPVETTE
Try this...just search for your year. i use it in my '22 Tahoe for my radar detector.
Hummin24
Dewally
Alabama
dancastro
I ordered this dash cam (front and rear) and plan to install it today/tomorrow. It has the correct mirror harness.
Looks interesting, but only 5 reviews & the guy who actually paid for it gives it 1 star....please update on how it works out for you.
Jimbo123
I have a friend who installed one in his BMW and said it's been awesome, as well as his VW. So, I decided to not pay too close of attention to the specific reviews for the Yukon. But, should know later this afternoon when I decide to tackle it.
JTGZ71
Any update on your experience with this dashcam?
rvaskippers
RST Dana
OH
I have one on my 21 High Country that powers my Redline 360.
ChoppedLiverpr
We went with this one…
Mangoal Front 4K & Rear 1080P Dash Cam Custom fit for GMC Yukon, Yukon XL 2023 2024 2025(Model A), SLE SLT AT4 Denali Denali Ultimate, Integrated OEM Look, UHD 2160P Video, G-Sensor, 128GB Card https://a.co/d/hJFb2ZC
Super clean and easy to install. Jury is still out on fu cation, and day and night quality.
Charlie21ny
