Air box question
Jobi-Wan Kenobi
I noticed the other day that my air box lid has a broken tab for one of the screws. I'm not sure what the assembly code is for it but its not the high capacity K47 option. I called a couple local salvage yards seeing if they would have one and no one did. But one place did have the K47 assembly in stock. Anyone know if this is a direct swap? Is even a worthwhile change?
I've never heard of that rpo. What makes it different/better then the standard airbox?
Kind of odd that the same part number appears to fit different engines, with some overlap between engine codes (searched a 2003 Tahoe RWD):
Maybe it's the one with that little doodads that tells you if it's clogged.
All K47 means is that the car takes a high capacity air filter. It is twice as thick and fits into the same airbox.
I have trucks with and without K47 and all run the same high capacity air filter, A3085C.
Double check for yours, I have GMT900s.
Jobi-Wan Kenobi
Jobi-Wan Kenobi
So I stopped and picked up the air box tonight. The bottom pieces are identical, but someone did remove the tube thing from inside of mine. The cover does have a restriction indicator.
Replacement and the original.
CKendrick
