2008 Tahoe no crank/starts and dies (solved)
Woody258
Good morning! Got in my Tahoe to head to work and this happened;
Starts, runs for a few seconds and dies
Repeated attempts and it either won't crank or cranks, starts and dies quickly
Battery good, lights bright, oil pressure looks fine when it does start. CEL came on a couple weeks ago but only get ERR when trying to read with an older code reader. Engine well maintained, no issues previously, ran good.
Has exhaust and a BB tune but nothing recently.
I immediately thought fuel problem but the crank, no crank confuses me. I had to take another car to work so I can't troubleshoot until tonight.
Any thoughts are appreciated.
Geotrash
Dave
Richmond, VA
Year and mileage would help us help you. Need to get a decent code reader on there to see what's going on behind the CEL. Anything we say at this point would be guesswork because there are lots of things that can cause this from a bad fuel pump to a poor ignition coil ground, to a bad throttle body.
Geotrash
Dave
Richmond, VA
2008, 171k
Thanks
Thank you. You mentioned that on repeated attempts sometimes it won't crank. That's a smoking gun to me that you may have a bad ground in the engine compartment. These trucks have multiple ground points so the lights and electronics may stay on while a bad ground kills the engine. Without codes or a reader, I would start by loosening, cleaning and tightening the ground point on the front of the pax side cylinder head. Loosen, clean and reseat the battery terminals as well. The trucks are notorious for bad/weak grounds causing all kinds of problems, and the battery cables themselves corrode from the inside out. They look fine from the outside but are incapable of carrying sufficient load with internal corrosion. Seach "Big 3 upgrade" here and you'll find all kinds of good reading to help you sleep.
Woody258
Woody258
Thank you! Gives me something to go on when I get home. It’s frustrating being at work and not able to work on it.
stocksj
Brandon, FL
I had a similar issue and it was a crankshaft position sensor. You may also want to check your fuses in the engine compartment and make sure they are all reseated as they get loose.
Marky Dissod
May not apply to your electronically signaled throttle, vs mine being a physically operated throttle ...
For the past two weeks, had what I THOUGHT was an electrical problem; my idle was living under 500RpM.
I was impressed, but did not realize it was a deeper problem.
One day, I went to start it after a short trip with lots of stop'n'go, and it tried to start but failed and died.
The extremely low idle was not allowing the battery to charge in stop'n'go traffic.
(Another reason why highway mileage is just better for any vehicle.)
In my case, the root problem was that the throttle body was dirtying up to the point that the idle was limbo-ing as low as 300RpM - yet it idled smooth enough that I did not recognize this as a root problem.
This eventually led to the battery being depleted by too much idling under 500RpM in too much stop'n'go traffic.
My next tune revision will raise the Drive-Idle to about 600RpM to keep the alternator excited.
A thorough throttle body cleaning and a brand new Idle Air Control motor were also called for.
PCV system needs a once-over. That's where all the stuff that accumulated on the throttle comes from.
Woody258
Woody258
Thanks for jogging my memory. I do have torque pro that I had used on another car way back. I’ll connect it when I get home.
I'm thinking fuel pump too. Get a modern code reader like this:
Get the Torque Pro App if you have an Android phone and set it up to read codes and fuel pressure.
he's reporting a no crank issue as well, so probably not fuel related
most likely going to be a ground or "maybe" even ignition related
my first thought was "security" but that will either do one or the other, not both as far as I know on the gmt900's
op: when you get back to it, start at the battery first, take the cables off and look for any hidden corrosion, even if they look clean wire brush them and re-connect.
that's a starting point.
Woody258
Woody258
Will do thanks. Yeah, whatever it is, seems to be effecting a few things. When it does crank, it turns over normally then fires for a few seconds, sputters and dies. When it doesn’t crank, it’s like the starter is disconnected. About half the time I turned the key, nothing. I’ll be home in a few hours and troubleshoot. Luckily its parked right in the sun :(
opfor2
Riverside County, CA
Did you test the battery?
Woody258
Woody258
Update, checked codes with torque app. Here's what I have
P069E – Fuel Pump Control Module Requested MIL Illumination​
P2534 – Ignition switch, ON/start position – circuit low​
P1682
Chevrolet
Engine control module (ECM) -ignition power supply variation
So I cleaned up the battery connections and ground point on the pass head and tried again. Same thing with crank sometimes and run a few seconds and mostly no crank at all. Then it started once and ran fine. I shut it off after 10 minutes and back to no crank.
Fuel pressure read 44psi
Could it be the ignition switch? I read there were issues with some.
Woody258
Woody258
Well I replaced the ignition switch since it was cheap and quick but it didn't help. Tomorrow I'll check all the fuses and reseat them
I just remembered that a week or so ago, the remote start stopped working. It would flash the park lights then nothing. At the time it was still starting normally with the key.
Did you clear the codes and if so, which ones came back?
Are you certain that your cables coming off the battery are corrosion free inside and out?
We have seen a few cases where the battery was the problem. Someone tightened the bolt too hard or pushed on the cables somehow which cause the connection inside the battery to become intermittent.
After the car has been sitting overnight, what is the voltage of the battery before you put the key in and start the engine? Best checked with a voltmeter. If you don't have one, set up your Torque Pro App to read volts. Well, I'm guess that it can!
P1682
Chevrolet
mmmmm maybe fuse box, seems logical. these trucks are pretty finicky about voltage
Woody258
Woody258
Ok, batt voltage after sitting was 12.45. I hooked up jumper cables from another car but no change. Pulled underhood fuses/relays and didn't find any corrosion. Switched relays for run/crank and starter and fuel pump w/o change. I pulled the fuse box up but couldn't raise it enough to unplug anything so I reinstalled it.
Heading back out to find more grounds.
Cleaned ground on frame under drivers seat area. Cleaned connections at fusible link.
Read something about the passlock security causing no crank or start and die issues. My security light is on in key on position but not blinking.
Woody258
Woody258
I was able to separate the main fuse box and clean the connections, also cleaned the main connectors on the ecm? In front of the fuse box.
Added another heavy ground wire from the engine to the firewall. Still nothing. Passlock security faulty? Any suggestions?
Thank you for your help. Thinking I may need to find z mobile mechanic.
Turn key on and dash.ights come on, cel and security light stay on
Turn key to start and you can hear some relay type noise but engine won't turn over
Ossipeelake
