denali center console
droppedHoe
Lawrenceville,Ga
i have a 2002 tahoe with out dual din but im gonna mod it and toss a dual din in with a denali gray wood bezel.
however id also like to change the console to a denali console with gray wood too.
anyone know where i can get a denali console? and are there any issues putting them in tahoes?
Anthony
2004 Tahoe LT (MA)
Westen MA
eBay, its a direct swap just make sure you get a 2000-2000 Denali console
Anthony
2004 Tahoe LT (MA)
Westen MA
Just use less....Its plug and play in the back and I think the denali has 3, just in different locations...I might be wrong...Someone with a Denali chime in please
D
droppedHoe
Lawrenceville,Ga
o ok. the one i saw on ebay with the gray wood only had one and was designed quite a bit different than my tahoe, but i like it
chevy1500
03 to 06 console
did you do your console yet? i was reading the post u can also put the 03 to 06 one in there too i have a 01 tahoe i converted my console to 03 denali pretty easy let me know if you need help
Z-56 Hoe
What do I do????
Houston
I have a 2001 hoe and have a 2003 / newer console and dash panels.
MrFleming007
Denali console has five plugs. One behind the door up top, one in the ashtray, one in the main console pocket and two in the rear.
Sent from my DROID BIONIC using Tapatalk 2
ntxstallion
I spliced all of them in my Yukon with a denali console. I took 12 volt power from various places with inline fuses protect. All five of them power now and I have all kinds of stuff hooked up. Don't forget, if you are using the Denali console you also need the part under the steering wheel and the glove box to make it all fit without problem.
AdrienR
