Rough idle/ shuddering in idle.
iboughtatahoe23
iboughtatahoe23
I think it's possible ONE of them could be bad. So in the ECM programming, there's a threshold that has to be met for misfire counts on a given cylinder/coil pack before it will set a check engine light. I don't know what that threshold is, but I can tell you from recent personal experience you can have a misfire without it turning the light on.
The symptoms you describe in your first post are almost IDENTICAL to what I experienced after I dumped that motor in the suburban, save that my truck would also misfire while sitting at a red light. It was definitely more noticeable when in park, it would be easily missed in drive if I hadn't worked on cars for 20 years. But look, I thought I was trippin at first, because even when sitting in park it was barely there. I'm used to cars either running so terrible you KNOW something's up, or the engine controls are so sensitive that when a gnat farts near your mass airflow sensor it turns your dash into a christmas tree. I'm like, there's no way it's misfiring. It would set the light if it was. Maybe I didn't tighten the manifolds up enough, maybe this junkyard motor has a bad valve seat, maybe it's a bad mount, maybe I'm just getting old. So, I bought that vxdiag tool off Amazon because I didn't want to wait for a Tech2 clone to get here from China.
So what it showed was that on cylinder 4, I had low double digit misfire counts. I forget exactly how it shows it in the Tech2 emulator but it's a real time data output from each coil pack. I had 7 coil packs sitting at 0 misfires, and cyl 4 would get to like, 15 misfires, and drop back down to 0, go to 12, drop down etc. I could watch the tach just BARELY seesaw in time with what I was seeing on the tool. So I put a new coil pack on that cylinder and since then this has been the smoothest running motor I've ever had.
I do wanna be clear, this may not necessarily be your problem. You could have something wonky going on with the cylinder deactivation. Worn cam lobe. Bad gas. Previous posters have talked about running premium regardless of if you're tuned or not, and I agree with them. The 5.3L LC9 in my burb has a 9.5:1 compression ratio, which should see at least 90 octane. I use 93. You CAN run 87 in them, the ECM will just pull timing. Keep in mind it's not about "will it run better" but more "will it run optimally". Higher octane=resistance to detonation. As long as you're not filling up at the country gas station out in the middle of nowhere, odds are you're getting good quality gas. Running E85 vs premium is moot around my parts- taking into consideration the higher consumption with E85 I spend the same money. BUT E85 also has a higher octane rating than premium, something like 100 if I remember right.
Put your plugs and wires in and see how it runs then, and report back.
I should have mentioned I have an exhaut leak too
iboughtatahoe23
iboughtatahoe23
This is what I will be running from now on. If you say this compression rate calls for 90 and up
iboughtatahoe23
iboughtatahoe23
I will add some times it feels like when I need accerlation, at certain speeds it feels like acceleration is just not there I feel so slow. Like pedal almost Halfway and then it will start to get up. I would say I feel the fastest acceleration is in 2nd gear.
Idk it might just be a slow car and im
Not used to it.
If it was a misfire I feel I would have an engine light.
iboughtatahoe23
iboughtatahoe23
Not used to it.
I feel like it might be so intermittent, if I do have a misfire that the ECU just doesn’t recognize it
iboughtatahoe23
iboughtatahoe23
So after driving a bit I stopped in park and the Rpm doesn’t seem to like drop. It stays at 600. There’s like hairline movements sometimes. But not enough to really see unless you really look at the tach
In reference to a possible misfire
Not used to it.
If the misfire is on the exhaust side lifters I don't believe it throws a CEL.
I've tuned my truck to a higher idle to reduce the rough idle but I'm fairly sure there's an issue with a lifter / the cam on my exhaust side which is why I never get a CEL
wjburken
Eastern Iowa
Yes. There’s a coin type that looks like it has a keychain hole but it’s actually where you can bend the tip without touching the delicate parts. Don’t use the Slide part to gap, only to check the actual gap. Use the little hole to widen the gap.
For platinum plugs, I like to use a wire style gap indicator like shown below. I’ve read where the wire style is less likely to damage the electrode, but that may just be me.
iboughtatahoe23
iboughtatahoe23
Just got my plugs in, going to set them aside for my day off on Monday. As I don’t see myself doing this in 3 hours. I have a needle nose plier and basic tool set, but don’t have that “gapper” for the plugs.
In the meantime I’m watching videos.
iboughtatahoe23
iboughtatahoe23
So all I do, is go through each spark plug and wire, one at a time? Seems pretty simple, Besides slicing my hand up over on the 7 and 8 cylinder by the ac compressor.
Is there any way I can tell how new the wires are without pulling them? And the plugs?
wjburken
Eastern Iowa
Yes. One by one. Get some anti-seize and some dielectric grease for the new plugs and wires. Put a little dab of anti-seize on the threads of the new plugs before installing them. Put some dielectric grease on the plug tip before putting the plug wire on it.
You can see the condition of the plug when it’s pulled, but necessarily the age.
Get a good spark plug socket and then find the size socket that fits over the hex end of it and on #8 plug, use the socket to turn the spark plug socket and it should get you out past the heat shield and not into the a/c stuff.
Take your time and it shouldn’t take you more than an hour or so.
iboughtatahoe23
iboughtatahoe23
Was wondering if anyone here has cleaned the fuel injectors? Do you have to remove a lot of stuff? I couldn’t find an exact video for my model and year
GMT800 2005 Tahoe Z71
Navy Supporting Member
I use Chevron Techron every 4th tank to help keep them clean. I use Chevron Plus fuel exclusively as well. There are some additives in the fuel you use as the price goes up. I have seen the problems in shops when driver's use the least expensive fuel, to save money, and ends up costing more later.
iboughtatahoe23
iboughtatahoe23
If I’m running e85, should I not just use additives and keep running it?
I’ve done a lot of things about this rough Idle. Wonder what else I could look at. I know the air intake is good. I wonder if it the intake manifold. I wonder if the rattling noise I am having is also the intake manifold…
j91z28d1
I just skipped thru a few videos on YouTube and none of them actually showed how to change one.
they all jump cut thru the hard part. lame.
I wish I'd have videoed installing mine.
j91z28d1
this the best I found, it atleast shows that bolt with the ground on it. that's the hardest part and even he jump cut thru breaking it loose lol tightening it as well.
petethepug
Michael
SoCal
They’re either going to break or come off. Option two is soak them with a penetrating lube daily, for several weeks. Then have at it.
Soaking all mine for 48 hours when the trans came out meant every single bolt got out safely. In my 08 Denali two broke and one had to be ground out with a dremil tool for several hours. Soak the ship out of the bolt you need to remove to add the clamp to.
Mckennahc
