Grade of oil
gapost
I'm no expert but I read a lot and have some experience with fleet vehicles. If you learn about the Dexos certification and the fact that GM recommends (for good reason) to use Dexos oil, then it might ease your mind about 0W20. Also, Dexos1 (for gas engines), is now a Gen 3 version and is better than the older Dexos1 oils. I keep an eye on our fleet vehicles, many of which use 0W20 oils (mostly Ford, we don't have many GM), and we don't see engine breakdowns as a result of oil problems. Our fleet vehicles change oil at 5000 miles in S. GA. Personally, I use the manufacturer's recommendation of Dexos 0W20 and usually base the oil change on the computer recommendation (which uses highly advanced calculations for oil life).
Marky Dissod
Where do we learn more about this? I'd bet we'd all like to be a lil bit more at ease.
I get why the professional thing to do would be to base the oil change on the computer recommendation.
However, the computer recommendation cannot analyze the oil's condition in any sense.
It basically just counts how the engine is treated by the driver(s) - tallying total engine revolutions, at what temperatures (is the engine abused when it's cold?), how high the engine RpMs go, how long it spends idling, that sort of stuff.
Professionally, the livery drivers I know with vehicles that've accumulated over 350,000 CITY miles on their GMT900s, NEVER let the Oil Life Monitor get to 10% or less.
Despite none of them disabling V4 mode, can't recall one of them having any lifter issues.
Long story short: it's not hard to do better than the Oil Life Monitor; how much better is up to you.
THarber
I have always ran 5w-30 in my GM engines and in the heat of a Florida summer I use 1qt of 5w-40. I change my oil religioulsy and prefer to use Royal Purple with Baldwin oil filters. I have never had any issues from my H2 to Vette to Yukon.
I also run 5x-30 in my twin turbo imports and have no problems with them.
gapost
I just did a search on the Internet.
An no, I would not let the oil life monitor go to 0, but it does help give you an idea about when to change it.
It's also interesting to note that Mobile 1 Extended is now saying you can get 20,000 between oil changes. No doubt many would not do that, but it is an indication of how advanced oils have become.
gapost
Here is a good video about Mobile 1 Extended oil. Among other things, they do a test on a Silverado 5.3 for 500,000 miles with 20,000 mile oil changes.
AngelXL
2016 XL. I see everyone talking about Mobile 1 0w20 or 5w30. Are you guys using Synthetic Oil or Reg?
I used to do my oil change at the dealership till the 36k miles warranty. I'm sure they were using reg oil.
After that I had been doing the oil change myself when the oil life comes on.
I'm at 64k miles and use Mobile 1 Synthetic 0w-20 but I noticed oil consumption between oil changes. 1 quart.
Should I go back to Regular Oil??
Marky Dissod
... been doing the oil change myself
I'm at 64k miles and use Mobil 1 Synthetic 0w20 but I noticed 1 quart oil consumption between oil changes.
No one should go back to dinosaur marrow.
If you notice 1 quart of oil consumption between each oil change,
and you wait for the oil life monitor to go down to 0% before each oil change,
seriously consider changing your oil SOONER, BEFORE 1 quart of oil consumption.
NYC cabdrivers / livery drivers / chauffeurs NEVER let the oil life monitor hit 0%.
If mileage is mostly all highway miles, change oil when the oil life monitor hits 17%.
If mileage is more highway than local, change oil when oil life hits 20%.
If mileage is more local than highway, change oil when oil life hits 25%.
If mileage is mostly all local miles, change oil when oil life hits 33%.
Also, deactivate V4 mode as soon as possible.
Even if the V4 mode lifters never fail, V4 mode itself increases oil consumption.
I know from personal experience:
I got my '12 Yukon XL tuned to INCREASE V4 mode duty cycle.
MpG went up immediately. Oil consumption went up after about 2 years.
Also, tune your ecm to lower the fan-on temp thresholds.
If the motor oil runs cooler, oil consumption will go down.
AngelXL
Do I need the dealership to turn off V4 or DIY project?
Any links on what I need to buy.
Thank for your time.
26AT4
