Wire clip/clamps
rezapci
Dearborn
Hey guys
I have a question
What is name of this clip are and what is the part number, I breaks while changing the wire heat shield ..
Thank you
rezapci
rezapci
Dearborn
What year and model, and in what area is the wire loom? How about a picture that has something to show the size? [Posted in the 2021+ Interior section]
Will thank you
My suv is 08 gmc Yukon SLT 5.3
Trilla_one
FL
I'm trying to find the same female clip. This one is for the firewall next to the battery.
Needing to replace some of my disintegrated split wire conduit and clips to prevent problems down the road
there are some connectors out there that are similar, but.... the only way to get new ones is to buy a wire harness as they are supplied with the harness.
you can find a accessory power harness with them sometimes cheap on rock auto or maybe ebay.
but for me the fix was to just hit the local junkyard and find some that were not deteriorated yet, you can open the zip tie part with a small flat head screw driver or pick tool
I now have several extra's in my tool box and all of them replaced that were crumbling.
Trilla_one
FL
Thanks for the tips. I'll hit up the local JY
Def need some new loom on there, the wire will rub over time and when the insulation wears down they short out and you will have all kinds of ghost in the machine, I am always under the hood looking for any wires rubbing, pinched, hanging loose or stretched tight, any resting on a hot spot, etc.
the loom isn't exactly cheap either, I have found "wire loom lot's" on ebay and got a deal on several feet of various sizes for a bargain.
something like this-->
or for a full line up
Trilla_one
FL
My thoughts exactly. Trying to keep the electrical gremlins away while things are still relatively good.
Just got back from the JY with an assortment of clips and new found skills in re-using them. I got some 3/8", 1/2", and 3/4" wire looms from Autozone already. Just need to get a few feet of the bigger ones over by the fuse box.
While we are under the hood if you or anyone has a solution for this sagging please let me know. It's one of those things that drives me crazy
HeavyHoe03
