YukonBrian
Yesterday, I finally sat down and took care of the wiring to install my junkyard Sierra seats. I picked them up on a whim last year when I found a wrecked truck with a decent looking interior.
The connection to the body harness is apparently in the front for Sierras, and the seat harness is designed to connect there. In addition, the new seats are lacking air bags, so I had to also wire in some resistors to get rid of the airbag light.
I started at the connector I cut off of the seat harness. I’ve never spliced wires before. I tried to solder the connections but apparently I need a lot of practice. So, I ended up using Solder Stick connectors that I always see on Lawrence Tolman’s videos. They worked like a dream with a big lighter and I was able to effortlessly get solid, soldered connections.
This is the drivers side seat with new wiring splice into the harness. The wires themselves were interesting to chase down. As I said, I’ve not spliced wires before, so finding 3 ft of extension was not easy for me, until it was.
I got the wire from the same shop that put in my stereo. I just brought in the connector I cut off and they let me have whatever I wanted from their scrap wire bin.
For the smaller wires, I was able to cut apart and use individually shielded wires from a ~3.5 run of Speedwire from Stinger audio. It had about 9 strands of wire running through it, which was the same gauge as the smaller seat harness wires. https://stingerelectronics.com/products/9-conductor-speedwire-20ft
For the larger wires, I just got a handful of 3.5ft long 12 gauge.
I made the connector extra long so I could test the seats outside of the truck. I regret that a little bit now, but it was a trade off for a smaller headache, due to my very limited working space in a shared driveway. The seats checked out fine.
For loom, I just for a 7ft run of 0.5in split, flexible hose and some electrical tape. I also wrapped each connection in electrical tape just to be extra sure there was no interference.
Once the seats were installed, I of course had to deal with the SRS light on the dash. For that, I wired in a 2.2ohm resistor that I got off eBay.
I clipped off the connector from the old seat with airbags and stuck the resistor on the end. I was happy to avoid doing any modifications to the body SRS wires, and everything turned out clean.
My only remaining challenges are to install the trim for the seats. For the rear, I don’t really care that the seat legs are exposed but it looks ugly in the front. I have the pieces, I just need to wiggle them in and I didn’t feel like figuring it out yesterday.
The lengthy harness is also something I need to take care of. There’s a good bit of wire under the seat so I need to use some zip ties to clean up the rear passenger floorboard.
The seats themselves were a huge improvement over my very tired Yukon seats. Mine are very cracked and tired, plus they are the ugly stock pewter color that shows everything.
Really happy with the results of this swap!
Jimmyy
Minnesota
You need a little more heat on your connectors next time. I have used these connectors with a heat gun and the solder does melt and covers the wires. They work great. I used them on some out door lighting 3+ years ago and have had no problems with them. They are water tight.
blueinkd
Which brand of connectors are we talking about here. I'd like to order some
nonickatall
Germany
Soldered new bulbs for my ac control, move microphone from my hands free device. (Do you call that like this?)
Guy had the ball$ to want $300--the gf got him to take $250, and the brakes are spongy. I bench bled the mc and there were no bubbles, but he says he bled that too, and he had to replace the brake line that HE previously installed. I didn't talk to the guy, gf did. What a douche.
Jimmyy
Minnesota
nonickatall
Germany
clandr1
Dallas/Fort Worth, Texas
They came with new rubber heads. I ordered them here:
I did this a while back and the new bulbs partially melted the backs of the buttons. I had to disassemble the unit again and break off the melted parts so the switches wouldn’t stick to the bulbs. Wish I’d done a led swap that looked like natural incandescent light, maybe I’ll do that next time they burn out. The new bulbs get extremely hot as well. I was kind of disappointed.
Keviebear86
I just ordered the front and intermediate emergency brake cables, Dorman cabin filter retrofit kit, rear evaporator core, ACS rear AC lines, and I'm trying to find replacement bushings for the steering stabilizer I bought from Rough Country because in less than 6 months they are falling off already. Hoping for a weekend where I can clear the garage out, crank some Pantera, and get to work.
nonickatall
Germany
I did the switches of the steering wheel once with LEDs, but that was absolutely nothing I liked because the light color was quite different to the other lamps and the dimming was totally different, so I changed that back to bulbs again. I have my light mostly dimed darker so I don't think I get a heat problem.
Are you sure that you soldered the bulbs right to the board, at not to close to the switches?
clandr1
Thank you for the feedback on the LEDs. I suppose it's possible I did not fully seat the bulbs, but from memory (this was about a year and a half ago) I believe I did... Either way, it's working fine now, and I usually keep the cluster dimmer about 50% to minimize the heat and hopefully maximize the life span of the bulbs. I need to replace the backlighting in my rear A/C control fore of the sunroof opening. Maybe I'll try to find some workable "warm" LEDs for that project.
Jimmyy
Minnesota
I used these on my radio. They are cheap and so far working good. Some of the rubber caps tore so the color is off a bit. They do come in colors but I used clear ones.
nonickatall
Germany
That's how mine look.. Difficult to make a photo without shaking with so few light....
First with interior light on and the other with interior light off....
blueinkd
Should be ready for first crank tomorrow with new engine. All that's left is starter, fluids, connect injector harness, harmonic balancer and drive belts. Probably going to double check all twice over before cranking it.
BEEN A long 6+ weeks since I parked it and yanked it out!
nonickatall
Germany
Good luck... I guess before you first start the engine, you let it crank first without fuel pump relais, to make sure that oil is everywhere where it should be?
Kman
Southern California
Changed out the front DRL (4114), front turn signal (4157A), and front side marker lights (194) to the Sylvania ZEVO LED on my 2001 Tahoe. Installed an EP29 flasher to get rid of the hyper flash while I was at it too.
Everything works correctly but when my headlights and parking lights are off and I turn my turn signal on only the 4157 bulb is flashing, not the side marker 194. The 194 isn’t illuminating at all. The 4157 front flasher and side 194 bulb do flash interchangeably when the parking lights or headlights are on. I put in the stock flasher to see if maybe that was the issue and noticed the 194 side bulb doesn’t turn on or blink if the parking lights or head lights are off. So maybe I’m remembering wrong but I thought both the front turn signal and side marker light blink together during the day when parking lights and headlights are off and at night they blink opposite of each other when the running lights / headlights are on? Hope that makes sense, I can post a video tomorrow if need be.
Just need some clarification if I’m remembering wrong or if I have a bad fuse or something?
Kman
Southern California
I figured this out. The Sylvania ZEVO 194 led bulbs are polarity sensitive. That’s why they worked in every case but during the day when the turn signal is on.
I returned them and have non-polarity led bulbs coming tomorrow. That should fix the issue.
I stumbled on this thread and it helped me diagnose the weird issue I was having. https://www.tahoeyukonforum.com/thr...er-lights-and-turn-signal-led-upgrades.90947/
Phlipnstik
