Lil’ Help - Question About ZW7 Code and Suspension Upgrade
Scott in AZ
Arizona
I’m doing homework on suspension for my 2001 GMC Yukon SLT 4WD. I’m leaning towards Bilstein B6-4600 front and rear, because seems like can’t go wrong with this choice. The spec for my front shocks are Bilstein PN 24-065009. My rear shocks are Bilstein PN 24-143806.
On Bilstein’s webpage there is a note stating “If vehicle is equipped with ZW7 Premium Smooth Rode Nivomat Suspension you must purchase Bilstein spring PN 199021 in addition to the damper.”
My original window sticker has a bullet that states "SELF-LEVELING REAR SHOCKS". I have RPO code ZW7 and G65 on the decal in my glove box. Does this mean that I have ZW7 Premium Smooth Ride Nivomat suspension and will need to replace the big rear springs when I replace the rear shocks?
Edit / Update - Yes, I am almost sure I have Nivomats, but would realy appreciate any input on which rear shock/dampener/spring to use.
Is there another “go to” front and rear shock combination that will offer equivalent good performance, and keep the old OEM springs? Or should I replace the springs regardless ? This SUV is not my daily driver but I still put 3-4K miles per year, mostly road driving with some forest service double-track mountain bike access, but no rough off-road and no heavy trailering.
Thanks!
mattbta
Frisco, TX
If you’re not replacing the rears with Nivomats, you must change the springs, too, as they mention. Other members have said it gets pretty squirrely on the highway without stiffer springs when changing to a standard shock with G65 & ZW7. Keep in mind that the rear height will raise, too. My original Nivomats are still doing their job well in my 2004.
I do have 5100’s up front and they’re pretty stiff. Considering the 4600’s.
leave the nivomats alone, change the front to bilsteins
nothing on the market will do a better job than the nivomats
if you decide to do it anyway I highly recomend not gretting rid of the nivomats because you will want to put them back on after you figure out the line I just wrote above this one.
besides if you get rid of them you will wish you had not, they are not cheap they used to be $500-600 (each) last time I checked, if they are even available anymore.
anyway just my .02 cents worth of advice
The Nivomats are fairly fat (girthy, LOL) compared to a conventional shock; here's a pic of mine on my '04. Same experience as @mattbta, mine are still doing great and re-level after adding weight and driving a block or two.
The G65 code is for the Nivo shock, and the ZW7 springs are softer than Z71 or standard springs.
I replaced my front shocks to the specified Gas-A-Just model (KG5040) from KYB and haven't really noticed a difference. Stay away from the cheaper KYB Excel-G; they don't have very good reviews. Check the catalog for model numbers if you're interested. https://www.kyb.com/
EDIT: you can test your rear shocks by measuring the bumper height, then adding 200-400 lbs of whatever to the rear. Measure the sag, then drive a few blocks to let the Nivomats adjust. Then re-measure the height at the same place on the bumper to see if they came back up to your liking. They are manual adjusting so they take a little "work" to recover.
Scott in AZ
Scott in AZ
Arizona
You guys rock. This is all great information. Thanks Matt, Wes, and Fless.
Yep, I have Nivomats in the rear. Mine look like those above. I guess I will leave them in place, keep the self-leveling feature save some $. Replace the front, probably with Bilstein. But I wonder about wear and tear on the OEM Nivomats. How long do they last? I've got 170,000 miles on my 2001.
In doing some homework on this I learned that both Bilstein (B4600 line, about $500 for the kit) and Monroe (OESpectrum line, about $250 for the kit) offer a replacement "kit" that features springs and shock/dampeners, with the same caution that you mention that the OEM springs that come with self-leveling Nivomat are too soft for standard suspension. I would lose the self-leveling feature, but I would gain zero-time on the suspension.... maybe I'll look around for Nivomat replacements.
TahoeRestore
Coincidently I just finished my parts order ($2K) for a complete steering & suspension rebuild on my 2003 Tahoe with 160K miles and a G65/ZW7 suspension. I had loose steering from an aging steering gear & other worn parts. I also has a leaking Nivomat. After a good bit of research, I decided to stay with the Nivomats. I loved the original smooth ride and occasionally trailer a 5,000 lb boat with a hefty tounge weight adding value to the self leveling feature. The best deal I found was at Rock Auto for $280 each. Part number - SACHS 030239.
FYI - My plan is to keep this truck. This work follows a complete paint job with all new exterior lighting. You can find that post on this forum. Next, will be the sound system and a few interior improvements. I will even renew the power train should it ever have an expensive failure.
Hops4Pops
I agree on sticking with the Nivomats. I just looked up the SACHS 030239 part on RockAuto. It shows 1 remaining. Perhaps you already purchased yours. If so, great! If not, here are the ones I put on my 03 Yukon:
GM Genuine 580354
Hope it helps you or someone else if needed.
TahoeRestore
GM Genuine 580354
Thanks for the heads-up. I ordered mine when when there were 3 in stock so there's 1 left.
clandr1
Dallas/Fort Worth, Texas
One of my Nivomats started leaking around 2017, so I replaced the rear shocks and springs with the Bilstein parts you referenced above. I've been totally happy.
mountie
I wonder...... on my '05 YukonXL...... 165,000 on the clock. Shocks still seem fine....
But I still wonder how long the Nivomats will be available, and buy a set for the future???
( In this day n age, I buy something while I think of it, instead of discovering they are no longer available in the future.....and way more expensive / kind of like an investment )
Thoughts ??
Thoughts ??
I don't necessarily worry about mine, but my last option will be to convert to standard (or Z71) rear suspension with new shocks and springs. Someone on here had some used Nivomats for sale a while back; if you want to know who, I'll dig a bit for that member's name.
mountie
If the Nivomats are "reasonably" new, I am very interested !!
Thanks.....:thumbsup:
kchotrodtrk
Louisiana
last summer with 265k on my o2 suburban w the original Nivomats, I loaded 6 humans, our luggage, and tv w PlayStation and headed out for key west, Florida, from baton rouge LA. (16hrs one way) the nivos gave a flawless performance. a bit later I took em off and added shock extenders and ranchos, but after a few thousand miles of swaying around on the interstate like a bay boat and decreased corning n towing, I today ordered a used set from a respected eBay dealer for 189$. gonna run them w my shock extenders.
kchotrodtrk
Louisiana
im not sure why my post count shows only 3 posts... I ve been posting here sporadically for years.
Scott in AZ
Scott in AZ
Arizona
Closing out this thread. Left the Nivomats w 171K original miles in place. They still work fine, pass the “Fless-Test” with no problem, loaded up with 5X 80 lb retaining wall blocks and our 48 lb little boy.
Installed Bilstein B6-4600 up front to replace the Monroe’s I’d put on in 2009 at 108K miles (at Sears Auto no less, during a “buy shocks get free install” promotion, they cost $60 each!). Noted that my bump stops were still original and they were shot! Mostly degraded. They are newly replaced now. I suspect the change to the Monroe’s 14 years ago has helped me with steering component reliability, so that was a really good $120 investment all those years ago.
My SUV drives the same on mostly smooth highway (as expected) but as soon as I get on double track jeep roads to the mountain bike trail or pass over a dipped intersection I can feel the stable and robust suspension upgrade right away.
One day I’ll replace the rear suspension w GM Genuine or Sachs but for now I’m (hopefully) done with this year’s summer overhaul (Front Struts and Cooling System). Thanks again for the good help and recommendations from this tribe.
Towmaster
