iboughtatahoe23
- Joined
- Feb 17, 2023
- Posts
- 1,133
- Reaction score
- 570
Would happen on my old one here too
No clue how to check, or if it is bad, how to change it. I know it’s way harder than a serp belt.Was your water pump pulley clean when you replaced the belt?
So what am I looking for again if the belts are rubbing against each other or somethingwell i meant when you installed the new pulley, if you happened to see if the water pump pulley had residue on it as well. It could be transferring from that pulley onto you new one. Water pump pulley is the large pulley under the idler you replaced that also rides on back side of belt.
I don’t think it’s wearing paint off. On my new pulley. It’s like bumps not indentations.It's just a wearing the paint off.. pulleys used to have a non-painted belt area. Manufacturers have made the process easier for them and just paint the whole thing. Nothing to be worried about.
If it was driving a waterpump, then the paint can cause slippage and noise. Pretty common on 8.1L replacement pumps. I've had to emery cloth off the paint on generators because they would squeal, slip, and cause the belt to get super hot.
You could remove it and sand off the paint if it makes you feel better about it.
Old pulley never touched new belt.looks like rubber residue from old belt to me. either way, i agree, dont worry about it!
Bc I am able to scratch it off.Pretty sure it’s belt material yall not paint wearing off. It’s bumps not indentations.
yes, but your old belt touched your old water pump pulley which is touching your new belt which is touching your new pulleyOld pulley never touched new belt.
So you think it’s my water pump pulley?yes, but your old belt touched your old water pump pulley which is touching your new belt which is touching your new pulley
Ya it’s just building up with rubber. No noises. And haven’t really looked at the water pump. That thing looks like you have to dump the whole front end to changethat is a bit weird but unless it damaging your belt or the bearings are making noise. I wouldn't worry about it much. just something to watch.
so the paint is fine, it's just building up rubber? and both the water pump pulley and the tensioner pulley are clean and it doesn't build up on them?
thats what i was thinking since there was residue on your old idler. doesnt mean your water pump is bad, just keep cleaning the idler pulley and see if it stops or lessens depositing rubber.So you think it’s my water pump pulley?
