GM 6L80 Transmission Information Thread
NickTransmissions
Sin City
The transmission bench
Hi All,
Since so many of us own at least one Tahoe or Yukon equipped with a 6L80, I figured I'd start an all-encompassing transmission thread with videos, links and other information as it relates to the 6L80/90 transmissions. I'll get it going with a tear down and inspection video and go from there. Hoping this can be an easy 'one-stop shop' for exchanging information, guidance and advice as it relates to 6L80 or 6L90 transmissions.
I'll update this first post with more over time and bump the thread when new stuff gets incorporated.
Feel free to post questions, comments, etc...
Note - Feel free to send me a PM as well but please provide your first name so that I know who I'm talking to - TIA.
2011 6L80 Teardown and Inspection
Special Tools Needed to Work on the 6L Transmissions
6L Transmission - Diagnosis and Troubleshooting, PT1 - Operating Fundamentals and Using Range Charts
Quick primer on TEHCM resistance testing:
> Review this article for the TEHCM testing procedures.
> Using a multimeter to test resistance for shift and pressure control solenoids (shift solenoids: 20-40 ohms; line pressure/clutch pressure control solenoids: 3-8 ohms).
shift solenoid
Pressure switch resistance (closed circuit): .7-1.9 ohms ( this is pressure switch #1 which sends a signal to the TCM reporting the status of the 3-5-R clutch reg valve in the valve body)
Pressure switch resistance (open circuit, pressure applied to switch) 11.5-12.9 kohms
> Use pencil eraser to put pressure on switch to open circuit
> Pressure switch resistance should drop back to .7-1.9 ohms or so when circuit is closed again (may vary a bit but should not be significantly different).
If any of those pressure switches are not reading like the above when you do this test, then the TEHCM is bad and should be replaced!
TSBs and other Tech Info
ATSG Manual
TSB - Cooler Bypass Valve
TSB - Pump and 3-5-Reverse Drum
ATRA - Intro to the 6L80
ATRA - Changes Over the Years
ATRA - TEHCM Diag, T&E
Installation procedures & fluid level check
GEARS Mag: Diagnosing CAN communication issues (no scan tool)
6L80/90 TSB - UU0073 Communication Breakdown Between Modules (including the TEHCM)
Parts List for Overhaul
PARTGM Part #Notes
Paper and rubber kitBW high energy or Raybestos Stage One unless full race
Clutch module
Kolene steel module for 3-5-R and 4-5-6 clutch packs
Factory steel module for 1-2-3-4, 2-6 and low reverse clutch packs
Bonded steel and rubber piston kitOEM pistons are made by National Seal
Snap ring kit for the 3-5-R and 4-5-6 clutch pack return spring assemblies24260139Early spring kit listed will service all years
Snap ring for the rear sprag assembly-to-center support24230752Will retro to 2006-E2007 units
Snap ring for the 4-5-6 hub damper cover plate
38 element sprag clutch assembly24248957Will retro to 2006-E2007 units
GM heavy duty parking rod assembly (2017 and older)2428004812.5" for 6L80E and 14.5" for 6L90E
Factory bushing kit
Thrust bearing kit (only needed if trans overheated)
Sonnax billet aluminum 1-2-3-4 apply piston
Sonnax 4-5-6 piston kitOptional but strongly recommended
Sonnax Zip KitTransgo Reprogramming kit is a viable alternative
Sonnax Oversized Clutch Boost Valve kitNecessary if one or more existing clutch boost valves fail vacuum test or prove to be worn; requires Sonnax reamer and related tooling for installation
GM internal mode switch24246427Updated switch will retro to years 2006-E2007
GM wiring harness and speed sensor assembly2012+: Application dependent and must match existing rear speed sensor design - consult dealer w/VIN
GM separator plateYear/application specific - consult dealer w/VIN
GM TEHCMOptional for later model units and strongly recommended for pre 2014 units; year/application-specific - consult dealer w/VIN
Sonnax pressure switch rebuild kit and toolPurchase if intending to re-use TEHCM
GM TEHCM filter screenPurchase if intending to re-use TEHCM
New Torque ConverterNew converter should come w/ converter clutch thickness => .050"; billet cover required for heavy duty or high performance
Machine Work
PumpMachine pump cover and body. Cut pocket to achieve .002 clearance between rotor/slide and deck surface
3-5-R DrumReinforce welds at the base of the drum (all years)
High Performance Options
Rear planetary carrier assembly with billet drive plateNot needed unless horsepower exceeds 700HP or if vehicle is regularly raced
Sonnax 3-5-R high capacity apply ringWhen installed and factory wave plate eliminated, this apply ring allows for an additional clutch and flat steel plate
Sonnax 4-5-6 billet clutch hub
Camaro ZL1 ConverterGreat performance upgrade as these are significantly stronger than the stock JMBX converters that come w/the 6L80E
Raybestos Blue Plate Stage 3 friction module
Complete Raybestos Kolene steel module
NickTransmissions
NickTransmissions
Sin City
Having successfully rebuilt a ZF 5HP24 that had lost 1st and reverse on my workbench, this makes me feel like I could reasonably do a 6L80 now too. Only problem is I hate doing the R&R.
Nice work. Those restrictors between the channel plate and spacer plate are a blast to deal with, lol. I did a few '19s last year.
The 6L family descended from the ZF6HP26 (same with the ford 6R series of transmissions). Both were designed/built under license from ZF. You should be able to handle the 6L80 if you got through the zf5hp24.
Geotrash
Dave
Richmond, VA
Do you mean these?
If so, it wasn’t too bad as I recall. The ***** was getting all of the packs to stack in place correctly for the final assembly. I did buy the special tool to compress the clutch packs, thankfully, or it would’ve been a real hassle to rebuild the individual packs. The failure in my unit was the A clutch drum. Wear in the pressure regulator bore caused pressure spikes in that clutch pack that eventually caused the snap ring groove to fail:
So I used Sonnax and Transgo parts to repair the regulator and upgrade the drum to a billet part. All new frictions, steels, bearings and seals.
I had no idea that the 6L80 was derived from a ZF design, but looking at the assemblies in the 6L80 from your video there are a lot of similarities. Thanks for sharing your knowledge - I’m grateful.
NickTransmissions
NickTransmissions
Sin City
Do you mean these?
You're welcome, man...
Nope, was referring to the valve body assembly in the ZF5HP19 - has literally 20 or 25 little restrictors that lie in their respective locations in the channel plate and will stick to the separator plate if you take it off without knowing to use a pick to unseat them so you know where they go. Each restrictor has a small orifice in the center and there's a bunch of different size orifices and would be damn near impossible to know where they went if you didn't keep track (unless you build those units every day).
Here's a few shots of the vb
Restrictors are at bottom right
Spacer plate lifted off channel plate to show all hydraulic circuit orifice restrictors
Geotrash
Dave
Richmond, VA
Ah yes, I remember now. All different color orifice pieces, if I recall correctly. One of the kits I bought had them all in a little ziplock bag that mercifully also contained a color diagram of where they all went.
Power_Dr
I have a question about the fluid exchange on a 6L80E. I would like to do a fluid exchange myself after I drop the pan and replace the filter. My question is, with the transmission thermostat bypass valve, how do you get fluid to be pumped out of the transmission via the cooler line if the transmission is not up to temp? If the bypass thermostat is not allowing the fluid to get out of the transmission?
Power_Dr
Nicki, what do think about mixing GM non-synthetic with synthetic transmission fluid? I was going to drop the pan and do a filter and fluid change. I was going to put back in synthetic GM fluid, but not exchange all the fluid so the synthetic would mix with the original non-synthetic.
NickTransmissions
NickTransmissions
Sin City
Nick, what do think about mixing GM non-synthetic with synthetic transmission fluid? I was going to drop the pan and do a filter and fluid change. I was going to put back in synthetic GM fluid, but not exchange all the fluid so the synthetic would mix with the original non-synthetic.
My name is "Nick" not Nicki.
You should have Dex 6 full synthetic in your trans and only use Dex 6 for any flushes or refills after you service it.
See my first post for the link to installation and fill/check level procedures - it will give you all the info you need to refill the trans and check the fluid level.
Note - You do no need to do a "fast adapt" if just replacing the filter and adding new fluid.
Power_Dr
I am sorry about the name, I thought I had typed Nick and I didn't proof read, my fault I apologize. So on my 2019 Yukon 6le80 has the full synthetic from the factory?
NickTransmissions
NickTransmissions
Sin City
No worries and yes, you already have full synthetic from the factory. GM went to full synthetic over conventional for a host of reasons - the first post has a link to an ATRA handout that provides info on the reason for the switch, if you're interested.
Power_Dr
I was looking at this fluid
that I thought was what I wanted to put in, it doesn't say synthetic, but then I see this
which says full synthetic. Thank you for your information, I just want to put in whatever would be the best for my yukon. thank you.
Power_Dr
So with those two gallon jugs that I just posted, why does only the one say Full Synthetic?
Charlie21ny
