'07 Yukon XL Denali Shocks
BSarteSr
On my 2007 Yukon XL Denali I have ~175k miles on it and the shocks have never been changed. It does not ride bad, I just figured it might be time to buy and install a new set. It has the electronic monitor on the suspension, I am not sure what to buy?
I don't want to break the bank here, just want to put new shocks on it for the OEM ride that it had when new.
Suggestions on how to figure out what I need based on any option codes I will need to look up?
Here is a list with the suspension RPO codes:
Your GM OE front struts are 19420493.
Your GM OE front coil springs are 15815635.
Your GM OE rear shocks are 19368463/580-1095.
Your GM OE rear coil springs are 25783732.
Replace all of the other parts that make up the strut assembly, the mount, boots, jounce bumpers, seats, etc.
If you cut corners, it will not ride the same as when new. Oh, check and see if the rear air compressor is new or not. It should have been replaced at least once by now.
You probably won't find new OEM springs for the front struts, as GM discontinued manufacturing them. I used a compatible Moog spring, and they work great.
As @swathdiver states, in our opinions the OEM suspension for this truck is the best. In full transparency, other folks in the Forum disagree.
Arnott makes compatible replacement struts/shocks for this truck with a great warranty, and folks have experienced great results with this product.
BSarteSr
BSarteSr
What is the difference between RPO Z55 & Z95 suspension?
Z55 suspension (Electronic/Autoide) controls the shock's stiffness by electrically changing the size of the orifice in the valve that regulates the shock's fluid flow rate. Response rate: 20ms.
Z95 suspension (MagneRide) controls the shock's stiffness by electrically changing the viscosity of the shock's fluid. Response rate: 4ms.
BSarteSr
BSarteSr
Thanks.
Geotrash
Dave
Richmond, VA
+1. In my opinion, the factory ride setup is unbeatable on these unless you're looking for a significant lift/drop.
Also, I have 233K on the original front shocks on my '07 XL Denali and they're still working great, with no leaks. If it ain't broke...
breds2k
Hey folks, doing some follow up here as honestly it gets a bit confusing depending on what/where you ask. I have a 07 Escalade i picked up last year. Front struts have been replaced with cheap quick struts that are blown and already have resistors on them. Rear air ride is leaking and the compressor runs once every 25 minutes which is getting annoying and it squats over night. So my goal is to get a belltech 2/4 kit, but i really need to replace everything first.
Id want belltech or bilstein struts in the front but without direction cant figure out parts number as there seems to be at least 3-4 different kinds for both, assuming the quick struts are junk, i think i need to play it safe and get all new components such as the spring seat, front coil spring itself (do not want one that sits higher as currently its maybe 1" over stock) top perch, bearing and whatever else. SO without piecing that through rock auto which actually gets rather expensive what should i do?
And for the rear, i dont tow so i assume i would just match the fronts with belltech or bilstein. Can anyone give me some incite on the best course of action keeping in mind this is a truck i bought last year for around $10k, want to keep it for years but keep in mind its a budget truck. Thanks for the help - Bob. Oh and its 2WD btw.
avalonandl
Troy, MICH & Naples, FL
Use Arnott air shocks from Rock Auto for rear.
breds2k
Why not replace with gas shocks if i dont care about auto level for towing? wouldnt ride worse would it? and would just eliminate the rear compressor and have less to fail?
wjburken
Eastern Iowa
You can definitely do whatever you want. It’s just that a lot of people spend a lot of time and energy trying to avoid paying for the “expensive” AutoRide and AutoLevel components and wind up with a worse riding vehicle or messages on their dash. That’s us why a number of us will default to suggest options that retain these features. B
If you replace the rear air shocks with non-AutoLevel shocks, you will need to swap out the rear springs as well.
breds2k
already have (but not installed) belltech rear springs for a drop. And already have resistor for the air ride removal that work good. So the question is that, would removing the air shock and replacing it with a belltech or Bilstein
strut really make the ride worse?
wjburken
Eastern Iowa
You should be fine from a ride stand point.
Keep in mind that the resistor only handles AutoRide. It does nothing with AutoLevel which is the airbag/compressor side of the equation. You will likely need to do some additional work to not get a suspension system error due to the vehicle not leveling.
When I converted back to the OEM Z55 suspension (I purchased the new-to-me 07 truck with crap passive shocks installed in the front and crap coil-overs in the rear) using all OEM parts except for the front springs (not available, so I used compatible Moog springs), it cost me about $3000. This included ALL front struts parts, front upper and lower control arms and ball joints, rear air shocks, compressor, and rear coil springs.
My ride height is stock, and I personally believe that you cannot get a better suspension and ride for this truck.
awsic
Looking through Amazon one can buy the front shock absorber (Z55 damping) from ACDelco for $339 each. As stated earlier in the thread, the spring and boot aren't part of this unit (not an assembly). For an assembly there is a Chinesium knock off for $480 (pair).
Has anyone tried the more economic purchase and if so, any opinion on the ride quality or build quality?
I think these are the Moog springs Joseph Garcia is referring to - $91.
Not sure on the boot or any other parts of the assembly... need to keep serching.
Go to GMPartsDirect.com, enter your VIN, and look for the exploded view of your strut. There you will find all of the parts that make up the strut assembly. That is what I did when I rebuilt mine.
CrackerJack135
