Scott in AZ
Arizona
Lil’ help? Power wire 8AWG thru Firewall Grommet.
Audio head unit + backup camera install is complete. Speaker and subwoofer is complete. Amp is mostly complete but I’ve hit a barrier.
I was not able to get 8AWG amplifier power wire through the firewall main grommet. Made a small incision in the upper engine side boot. Used Klein wire lube. Fished and poked around for about 40 mins but didn’t make any progress. This will be a really clean install when complete. OCD’s (you know who you are…) don’t hate on me! I offset the amp to pax side (right) to give more clearance for wires and avoid the groove in the console mounting plate. Form follows function. Now I just need power.
Anybody got tips on how to get thru the firewall?
Also, grounded with an 8AWG to floorboard but added a supplemental ground to the seat and console mount plate, which I believe is grounded / connected to the frame. I sanded paint down to bright metal under the supplemental ground , but can anybody confirm if this will work? @iamdub, will this work?
Thanks in advance.
I think that one you were trying with is dual-layered. I don't bother messing with the factory grommets. It's just not worth the hassle or risk of nicking a wire or causing a leak. Bring a piece of your power wire to an auto parts store or hardware store (Home Depot, Lowe's, etc.) and look for a grommet like this:
You want one that fits firmly on the jacket of your power wire. Here's mine where I ran it through the floorboard, near one of the right rear seat mounts:
I drilled the hole to the OD of the recess in the grommet ("PANEL HOLE DIAMETER" in the following image), cleaned the drilling burrs from around the edge of the hole then painted the metal and let it fully dry. The wire needed a little spritz of lubricant ever so often to slide through the grommet cuz it was a firm fit. Which, is what you want for proper sealing.
"OCD" you say? :D
Not directly. The seats are bolted to the cab floor, to sheet metal. A circuit needs to have the same ampacity throughout all of its conductors. Otherwise, the ampacity of the smallest (weakest) point will be the circuit's maximum. The battery is grounded to the frame. The body (sheet metal) is grounded to the frame with some rather electrically weak cables. You can ground that amp to sheet metal or to seat frames, etc. that are bolted to the same sheet metal, but that sheet metal needs a matching ground to the frame. So, you'd need an 8 gauge ground from the body's sheet metal to the frame or engine block. I have a 4 gauge ground from the body to the engine block, which is grounded to the frame with 1/0. It's actually the original factory main ground that went from the battery to the engine block, just relocated to the sheet metal:
Thanks in advance.
It's a good ground, but still to the body. The body-to-battery (or frame or engine) needs to be at least 8 gauge.
Honestly, it's all probably okay. But, there's still room for doubt. For the minimal cost of ensuring your grounds are sufficient, you can ensure the amp won't be starved of power, minimizing its heat and how hard it'll have to work which maximizes its life.
Scott in AZ
Arizona
This is really helpful information, @iamdub. Especially the grommet geometry cartoon. I can see now why I had so much trouble with my other grommet (different application; first and only grommet). I drilled to the ID and not to the Panel Hole Diameter.
Your power wire grommet is artwork. I’ll drill thru the floor near the rear mount of the front seat, Near my ground.Oh-See-Dee, yo! Thanks.
Thank you! I detected a bit of OCD from your previous posts so I had to feed in a little.
Unless I need the power wire to end up behind the dash, I like to come through the floor since there's so much more room to work.
You gotta consider the wire routing, too. If you run it along the frame, you're gonna have to hop from the frame to whichever seat mount you choose. So, look ahead for safe routing and secure mounting points before you poke that hole. I'd pick a spot nearest the frame so you're not stretching the run laterally once you leave the frame with it. Once inside the cabin, it's all easy from there since you can run the wire under the carpet to the center console. I came up by the seat mount so the cover panel would hide and protect the wire, nobody steps there, etc.
To paint the area I drilled, I couldn't get the can in there and I didn't wanna risk painting the carpet. I sprayed the paint into a plastic cap from a brake parts cleaner can then dabbed it on with a Q-tip.
blueinkd
"OCD" you say? :D
You make me want to Build my own ground straps!!! Im assuming you are making those in house??
What kind of ring terminals are u using?? Care to point me in the direction of your supplies??? That wire loom is sexy too!
I JUST replied to your other thread about the "while I'm rebuilding the engine..." stuff.
Yeah, I made 'em up at home. It's 1/0 welding lead, so it's OFC and not the cheaper, lower-quality CCA. Lugs are from Amazon. I soldered and crimped them on. Heat shrink tubing (also from Amazon) has adhesive sealant that activated when you heat the tubing to shrink it. The mesh sleeve is leftover extra I salvaged from a past project at work. It's cheap on Amazon. Here's an example: https://a.co/d/3ZrSOyQ. Note they have different sizes and colored options as well. I have a handheld hydraulic crimper- yup- from Amazon. The most expensive part is the wire. Just aim for OFC instead of CCA. Determine the highest amperage you'd ever need to support (have or are planning a big sound system or other high-amperage equipment?) and get the appropriate size of wire. For a given ampacity, you'll need a larger gauge of CCA than OFC. For a somewhat rough example, 4 gauge OFC is good for 100 amps (as with a ~1,000 watt amp). To support that same amperage, you'd need a step or two larger CCA.
Know anyone that works at a plant or is a welder? Safety guys often fail welding leads that have too many cuts. For a Big 3 upgrade, you'll need about 12' but that's cutting it close. If you can find a welding lead that was taken out of service, get as much as you can and cut out the good sections to make up your cables. I made a "Big 5" since I upgraded the starter wire and body-to-frame cables.
915_Tahoe
Your GM Parts Specialist
HELL PASO, TX
Hoe has been sitting for almost a year, and finally got her moving again.
Fixed-
replaced inner/outer tie rides
Installed longer torsion key bolts
Wheel alignment
State inspection and renewal
Replaced RH frnt leather seat covers
RAMurphy
Bob
Military
S. Maryland
"OCD" you say? :D
Looks like the amp I have installed in my baby. Nice job, looks great.
Sam Harris
I was checking my trans fluid this morning and heard a bit of noise from the passenger side, and don’t hear it on the driver side. Wondering what this might be. Should I be concerned..?
I would always be concerned when there's a distinct sound difference from left to right banks. First would be to check the exhaust. There's less accessories on the passenger side, so that's a bit unsettling. But you could still remove the belt and turn off your A/C to rule those out or at least to remove their noises when diagnosing. Have a mechanic's stethoscope?
Sam Harris
Nope. Need to pick one up. ordered. Be here tomorrow. Yeah, first thing I thought of was an exhaust leak. Shouldn’t be, used ARP bolts with the headers, but hey, that would be awesome if that’s what it is.
mwilson62000
Senior Member
Good point. I forgot to look at that. I just looked at tread and no signs of any dry rot or cracks. And it held air. Of course can’t be any worse then the one I already had. That may have been the original from 05. And was only 16” wheel.
You should check the date code on it. Looks good tho.
915_Tahoe
HELL PASO, TX
So heard a noise going over a speed bump, I stopped and turned the wheel left to right and noise was worse.
Got home popped the hood and found out the idler arm bracket was loose, was just rocking back and forward while turning the wheel. Tighten up the two 21mm nuts and bolts, but noise was still there. Turns out there is tons of play in the pitman ball joint to steering link, that was the issue. Placed an order for replacement idler arm w/bracket and pitman arm.
Escalade2007
