Engine turns over but won't start?
muncie21
My money is on the fuel pump control module. If you decide to replace it, remember it's coded to your VIN.
T
Timee
ya don't leave us hanging, knowledge is usefull for people exeriencing the same or similar problems down the road.
Got you I got told by the tuner to use some dielectric grease didn't have any so used a tiny bit of Vaseline on the plastic parts and plugged it in that got the engine running. The engine was running really rough and threw out all of those codes went back to the throttle body pressed the butterfly plate didn't know if it was stuck then put the throttle body back on tight. Cranked it back up everything was back to running smooth.
Geotrash
Dave
Richmond, VA
THANK YOU for following up! Glad you got it going!
Pepper1700
