Dome light function
Trilla_one
FL
I want only the rear dome lights to turn on when a door is opened, not the front lights. Pretty much every other car I've owned allowed this (door/on/off) function right next to the light. All I see with the Tahoe are the two on/off buttons for driver and passenger lights and then the dome light button next to the headlight switch. If this is possible please let me know.
mikez71
I'm not so good at reading these GM wiring diagrams, but looks to me like you can disconnect orange wire (A)?
Map lights should still work..
---------------- CORRECTION EDIT ------------------
Green-Yellow wire (B). the diagram shows the front dome switches switched on, I believe it is the GREEN-YELLOW that is controlled by BCM..
Trilla_one
Trilla_one
FL
Thanks but it may as well be in Chinese lol
mikez71
Unplug your front dome light and disconnect the green-yellow color wire.
If you do this, nothing will turn on the front dome light, except for the buttons on the light.
If no understand, I no can help.
mikez71
Actually.. I believe it is the GREEN-YELLOW wire..
Orange is power for switch controls
So try the Green-yellow..
The diagrams threw me showing the switches flipped on instead of off. (while all other dome lights are shown switched off)
Also, if you do unplug the wire, please make sure to tape up the end so it does not short!
Meathead16
GM loves their dome lights on their vehicles to be proud and shining bright! My Pontiac has no means of turning off the map lights in the rear view mirror and drove me nuts. Living in the ghetto, last thing you want is your car and its contents all lit up every time you shut your car off. I just took that there wire Mike is referring to, installed a simple toggle switch, drilled a hole near the light assemblies and boom, complete interior lighting control. You never know when you might need that light, options are always nice
JeffK
