Trey Hardy
- Joined
- Jun 12, 2020
- Posts
- 3,552
- Reaction score
- 9,637
My Tahoe diddnt have the external cooler from the factory like my truck did.if you are using the trucool then these are the adapters and lines you need 2 of each
BTW the an lines referenced below hold like 1200 psi far and beyond external trans line pressure
first pic is amazon, 2nd pic ebay
Therefore I had to T the inlet going into the radiator and bypass through the cooler and back into the radiator.
I’ll try to get pics after lunch to explain
It is however not a professional job by no means and I would like to swap to AN lines throughout for a tighter/ cleaner look but for the time being this is going good
