Old black Betty build
T
Trey Hardy
if you are using the trucool then these are the adapters and lines you need 2 of each
BTW the an lines referenced below hold like 1200 psi far and beyond external trans line pressure
first pic is amazon, 2nd pic ebay
My Tahoe diddnt have the external cooler from the factory like my truck did.
Therefore I had to T the inlet going into the radiator and bypass through the cooler and back into the radiator.
I’ll try to get pics after lunch to explain
It is however not a professional job by no means and I would like to swap to AN lines throughout for a tighter/ cleaner look but for the time being this is going good
T
Trey Hardy
Guess what’s inside the valve cover now!
If I diddnt have bad luck I wouldn’t have any luck at all!
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
View attachment 394094Guess what’s inside the valve cover now!
Not a big deal to pull the cover off to remove the debris. Just throw that PITFA POS extension neck in the trash. The oil cap will fit nice and snug directly to the VC. You'll just need to use a funnel to fill now that's all.
T
Trey Hardy
Yea I know I just diddnt want to pull the valve cover but more then likely will have to
It happened yesterday
I left today and won’t be back until Sunday night And I go to work wensday
89Suburban
SE PA
You can look in there with a flashlight and use one of those gripper tools to get anything out of there. Broken piece shouldn't have gone far unless the engine was running.
89Suburban
SE PA
New speaker wire in the doors pre gaming for the highs amp
Beside it is the stock wire
Pretty over kill but screw it
Reminds me when I had to make a power window switch when my factory one took a cht, had to MacGuver it until I got it fixed. Always appreciate some good home grown American ingenuity keep paddling up the river bro
T
Trey Hardy
It’s rough as shit out here today!
T
Trey Hardy
Haven’t done much of anything. I was supposed to get a smoked Cadillac style third brake light for my birthday but my ac compressor shit the bed on my way home and 600$ worth of parts later messed my spending money up for truck parts go figure.
She’s dirty but got some sunset pics yesterday to Ocracoke island
On the to do list
Powdercoat lift
New taillights Cadillac style smoked ones
Fix the ding in my bumper and repaint it along with a Cadillac step pad with the chrome trim on it
Drewphil
