Fog lamps not functioning
03yukXL
Hey all,
I replaced the destroyed fog lights in my 03 Yukon. They still do not function. Fuses are good, swapped in a known good relay. led indicator comes on the dash when the fog light button is pressed. Is there a common fix for this? I have read a couple of common complaints but never saw an answer…
Thanks all
RST Dana
OH
Hey all,
Thanks all
Didn’t you check voltage at the bulb? Did you replace with LED bulbs by chance? If so, flip them 180 degrees.
03yukXL
Full disclosure, both new lights were bad from the factory. Kept the housing and replaced the bulbs with LEDs. All functioning now. Careful what you get on amazon…
S33k3r
Dallas, Texas
Out of curiosity, where did you get the replacement bulbs?
ScottS-Michigan
