Magnetic Ride Control vs Air Ride Suspension
Status
Not open for further replies.
GoNoGo
Elberton, GA
Anyone test drove vehicles with MRC and MRC with air ride to see if they are different?
I have both a 2021 mag-ride equipped Silverado crew cab 5100-lbs 157" wheelbase with 20" tires, and a 2023 Suburban with both mag + Air ride, 6016-lbs 134" wheelbase with 22" tires. Both have the same 6.2L L87 motor.
Surburban is 2-ft shorter, 900-lbs heavier and has thinner-sidewall, stiffer/sportier tires, so not perfect vehicles for comparing suspensions.. but
Silverado feels more nimble and quick, rides comfortably, Suburban is a tad boat-like in the steering and a smidgeon sluggish on acceleration but maybe it's L87 need's broken in. Suburban is slightly more softer ride on asphalt roads (than Silverado) and may sound crazy, but the Burb's feels big, can't tell its 2 feet shorter.
GoNoGo
Elberton, GA
Oh, almost forgot that with Air Ride, the GM SUV's have the option to lower 2 inches at shut-down for easier occupant(s) ingress-egress.
WalleyeMikeIII
Sunny and Snowy Minnesota
I drove a NON air ride Suburban before buying my Air Ride Yukon XL. Both ride very similarly...I primarily wanted Air Ride for towing, to keep things level. It is worth it for just that if you tow often. As for ride management, unclear it really makes much noticeable difference in feel, it probably does help handling when you have the rig loaded down.
GoNoGo
Elberton, GA
I live at the end of a 3.5 mile long stony-dirt and washboard-gravel road so it's on these type bumpy and other rural county roads that Adaptive Ride Suspension, Magnetic Ride Control and Air Ride Adaptive Suspension seem to shine. My body can really feel the difference between the 2 vehicles equipped with, than my similar-size/weight Silverado's without :thumbsup:
WalleyeMikeIII
Could it be the independent rear suspension vs the solid rear axle/leaf springs of the Silverado?
GoNoGo
Elberton, GA
Naturally the suspension variety is an element,, my '06 3500 Silverado 8' bed quad cab and 2021 Silverado HC quad cab w/6.4' mid-size bed 1500 with magnet ride are night and day ride differ3nce, so maybe not a notable comparison.
BUT.. there's a notable difference between the shorter/lighter 2023 Tahoe HC with mag and Air ride and the heavier/longer 2023 Suburban HC with mag and Air Ride, so much so that I got rid of the 23 Tahoe and bought another new Suburban HC with mag and Air ride (this time with a Duramax 3.0).
I did lower the air pressure in my 22 inch tires;/wheels down to 31 psi cold to soften their ride.. I may consider to install 18" rims on the Suburban's when their tires become significantly worn.. time will tell
adventurenali92
Big Bear Lake, ca
There is one drawback in my mind with the Air Suspension…….Pertty much all current technology Air suspension vehicles, all manufacturer.
The system will hunt during parking, low speeds, etc……..This “hunting” obviously cycles the compressor. Obvious effect is early compressor failure compared to the MRC or even normal NON MRC suspensions.
Example…..Drive Thru……I am old school and was taught that if the vehicle is NOT in motion, then Place Transmission in Park….simple as that. I usually use the one minute rule but can be adjusted as conditions permit. The Compressor will cycle to Entry/Exit mode…..transmission thinks in park then we are getting out. Drops to full down. Twenty seconds or whatever it is, back to drive and raises. Repeat process at next sopping point.
Correct my if I’m wrong but I thought that with the air ride suspension option there’s an settings option to keep it at normal ride all the time or have it only drop to lowest setting when the vehicle is shut off?
Vint91
Do you have Settings that change your ride position to be more comfortable when driving so that you don’t have to air your 22 inch tires down to 31 psi? That seems pretty low?
MoonTruck
Correct, you can enable / disable the egress height. I have mine off, I still do hear the bags hissing when I turn off the car.
Nokturnal
With the edgymods adj end links the vehicle can be locked into one position for all time. Parked, driving, neutral, always one setting and no adjustment. Will this help with compression life maybe? Just bought a 21 z71 so curious to see how it goes with the edgymods
Kpwweb
The Edgymods don’t lock the suspension into one height, they spoof the sensors into thinking the vehicle is at a different height than it actually is.
I have the Edgymods and can still adjust the suspension up and down via the dash control. Up and down are different heights now.
Nokturnal
The edgymod owner told me that during driving the air ride would typically change its height (without pushing button) and would also lower height (without pushing button) during vehicle entry mode (if activated). He said his sensors could be used to keep the ride height the same and not let the computer send the message to alter height. I know what you’re saying but he made it clear the vehicle will modify height depending on speed etc. I fact checked it on Chevrolet as well. It said it would deprogram ride height adjustments that took place during “non push” button moments.
Once they’re installed it must automatically override the non button adjustments. I figured the air bag system just adjusted height as you selected it, but it also does it during other driving conditions without the button.
dbphillips
Wha-aaat? They really should be so close you can't feel a difference if they have the same wheels. Must be the longer wheelbase. If I could give up the capacity and had a longer garage at the time, I definitely would have preferred the suburban.
tagexpcom
I recently purchased a used 2021 Yukon Denali w/6.2 and 22" wheels but it's Magnetic ride only. Is there a straight-forward OEM kit to add air-ride/leveling or is this just too-late / kind of 'out there' since it wasn't added factory wise? Google doesn't show anything leading me to think it's crazy to entertain this idea.
I like the idea of auto-leveling for towing but my trailer w/WDH only brings the rear down 1" and the ride is fine - so it I'm probably wanting what I don't have rather than having actual need. I found a link to stiffer springs which would probably reduce the 1" to 1/2" - and seems like they'd just swap in with no issue and 1" - 1/2" drop is not that much with 37" from ground to fender before the drop.
I'd be interested in comments on air-ride-retrofit vs stiffer springs vs leave-well-enough-alone.
My 2004 Cadillac SRX V8 AWD has auto-air-leveling, still works at 170,000miles and 19yrs, which is nice when towing pulls the rear down or loading it up heavily but I have to say the 2021 Yukon rides smoother than the SRX.
WalleyeMikeIII
It’s probably possible but far from straightforward. Somehow you’d have to crack some of the modules and be able to program them to perform the air suspension functions…given how locked down it all is, you probably can’t do it without the assistance of GM engineers and the factory module programming..and even then, maybe not, since it wasn’t included on your original build.
olyelr
Elk Rapids, MI
Converting to the eom air ride system would be extremely difficult, time consuming and very expensive. If you really want it i would say your better off selling your current one and buying one that has the option.
a4edwin
ny
my 24 Escalade premium plus came with the zw7 suspension package. For a 100k suv I think it’s garbage. It’s the only think I hate about the Escalade.
WalleyeMikeIII
Didn't get the correct options...Both Magnetic Ride control and Air Ride Adaptive suspension are available on that model.
On the Up Side, you got miles of OLED displays in the dash.
Antonm
Can you elaborate on this?
The Edgy mods links are just that, metal adjustable links (see pic below). They don't interface with the computer at all, what they do is physically place the stock sensor in a different location relative to the suspension height. No programing programing changes occur, whatever the computer would do before, it would still do it after installing the links
Are they maybe coming out with some new product that's not listed on their website yet that they were talking to you about?
ChrisYukon
Hello all!
First time placing an order for a GM vehicle - I am in the midst of placing an order for either a 23 Suburban or 23 Yukon XL. Understanding Magnetic Ride Control is the standard suspension on the higher level trims and they do already ride smoothly, I was wondering if Air Ride Suspension provides an EVEN better ride quality?
A source of confusion has always been does the Air Ride Suspension replace the Magnetic Ride Control if selected as an option? Or is it an add on and works hand in hand with the Magnetic Ride Control?
Any feedback or explanation will be greatly appreciated! Thanks!
My '17 Denali had just Magnetic Ride Control and rode fantastic. My '23 has MRC WITH the air suspension, and it rides 10 times better. So - Yes!
Status
BadDaddy2003
